Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
Wont restart after power surge & verifying power supply restored
Used in office kitchen. experienced power surge in building that caused problems with other equipment. GFI checked, circuit breakers checked; electricity to machine is restored but machine will not start. cannot run diagnostics in user manual. is there a reset on the machine?
    President:
  • 1,865 Answers
The control board may have been damaged by the power surge. You should install a surge protection device on the incoming power line, thereby protecting everything in the home from damage.
If you need help with this, go to the following website and fill out the form, be sure to include an email address
http://taeckertindustries.com/prod04.htm
Posted on Nov 17, 2009
Laserjet 4100 Has an annoying beep on print. How do I disable it?
The plug needs to be into the wall outlet. If it is in a surge protector, the electric flow can be interrupted and cause the beep.
Nov 27, 2014 | HP LaserJet 4100 Printer
42 inch flat screen sanyo wont power on wont do nothing bought 2 years ago
Power surges, such as those caused during lightning storms, can often cause power supplies in electronics to fail. Sometimes, if you're lucky, the manufacturer will have placed a protection fuse in the power supply which can be replaced after a surge. If there is no such fuse, the power supply typically will need to be replaced for the equipment to regain function.
It is VERY IMPORTANT to use SURGE PROTECTORS on all electronics, especially if you live in an area where thunderstorms are commonplace. This will protect your electronics from most (not all) surges that would otherwise zap them into failure.
May 24, 2014 | Televison & Video
We get frequent power surges in this building and bought this to keep the computer on, but when the power surges the UPS says power overload and beeps until it is restarted.
The power overload warning should only come on if you have too much of a load plugged into the UPS. You may be close enough to the edge of the limit so the disturbance from a surge can be enough to trip the overload detector.
Your UPS is rated for 1200 Volt-Amps, so it can drive a maximum of 10 Amps at 120 Volts. Every piece of equipment should have a label with the maximum Amps or Watts on it. Add up the Amps used by the equipment plugged into the UPS/AVR sockets to make sure the total is less than 10 Amps. If the equipment label rates power requirement in Watts, divide that number by 120 Volts to get the amperage. One thing to read carefully is the label on the computer power supply. It is commonly rated in output watts, but that is not the number to use for this calculation. Since it is not 100% efficient, you need to look for the input Amps number.
If you are too close to the limit, move the printer or monitor to a surge-only outlet or consider replacing the monitor with a more energy-efficient unit. If your load total is less than 9.5 Amps, the UPS may have a defect in the power overload detection or internal voltage regulation circuits.
Sep 09, 2011 | CyberPower CPS1200AVR (CYPCPS1200AVR) UPS...
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
PRINTER SHUTS OFF BY ITSELF HAVE TO UNPLUG IT BEFORE YU CAN PRINT AGAIN
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&st=1&rf=0&qs=&tridion=0&hpvc=sitewide&uf=1&qt=Officejet+8500
Issue The HP product repeatedly turns off. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Cause When low-power problems exist, the product might turn off repeatedly. Low power is a common problem in many home offices because of the number of electronic devices concentrated in one area. Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01941590.gif
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Tv power flashes like it wants to come on but wont
I hate to be the bearer of bad news but the power supply in your television is shot. What happens during a power surge is that you have a buildup of power either at the wall or even in power supply of the TV from a sudden shut down of electricity. Now when current is restored, that build up is all shoved into your electronics all at once.
The quick of it, is that your power supply can no longer maintain a steady stream of electricity to all the components in your TV and so it keeps trying to restart the unit in the TV.
My advice is to bring the TV to a certified technician or contact the manufacturer to find out about getting some warranty work done on your TV. Otherwise, if you're paying for it out of pocket, weigh the cost of the repair vs a new panel.
To avoid this in the future, make sure you acquire yourself a surge protector power bar, for flat panel TV's it is always a good idea to spend a bit more on a protector as they do so much more than just prevent surges to your electronics. Let me know if you want some more information on them!
Best of luck!
Dec 09, 2009 | Televison & Video
Power supply shot when 3 weeks on same surge prot. all other eq. ok
YES !! IT CAN DAMAGED THE POWER SUPPLY , WHAT i SUGGEST IS TO USE AN APC BATTERY BACK UP & SURGE PROTECTION , SAME USE FOR COMPUTERS , FOR MORE INFORMATION GO TO:
http://www.apc.com , hope this helps , AJ
May 18, 2009 | Maxent MX-27X1 27 in. HD-Ready LCD...
DENON AVR 2308 no longer works only after 3 weeks of purchase!!!
You need to get more details. What component has failed that makes them believe that a surge caused the problem. There is usually a thermal fuse inside of the main power transformer that CAN be effected by power surges. WIthout more details, I really can't rpovide any ammunition for your claim. Please request exact details from the servicer.
Thanks,
Dan
Mar 05, 2009 | Denon AVR-2308CI
My power company killed my power to install a new meter. My two PC were downloading files off the net when the power was shut off with out warning. when i tried to restart them PC #1 showed a DISK BOOT...
Yes, a loss of power CAN cause your hard drive to not function when you turn it back on; as an experienced PC tech I've seen it many times before. However, your problem likely could have been solved had you booted with a boot CD and ran a chkdsk command.
Jun 21, 2008 | Compaq Computers & Internet
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
410 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
