Question about Bosch Exxcel WVT3250 Front Load Washer / Dryer
Not drying correctly leaving residue on clothes
  • 72 Answers
Its uncommon for elect dryer to put res on clothes your vent must be stopped up
Posted on Nov 17, 2009
How to get out sticky stuff from dark clothes
http://www.howtocleanstuff.net/how-to-remove-sticker-residue-from-clothing/
Sep 22, 2014 | Clothing
I have a battery door that was cleaned and now is sticky, how do I get rid of the sticky feel? It was cleaned with alcohol.
Its very unusual for alcohol to leave a sticky residue, however try wiping over with vinegar, or even petrol that is for lighters. Put either on a cloth, (don't soak the cloth, just dampen it) and gently wipe, leave to dry. try that.
Jul 06, 2014 | Canon Used EOS A2E 35mm SLR Autofocus...
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Have residue on most to all clothes. i thought it was a water softner problem but that is now fixed. any ideas?
    Residue is almost always soap related.
    1: Soap goes in the washer first, then clothes. The other way around leaves soap on clothes.
    2: switch to concentrated liquid soap. This blends better with cold water.
    3: Dry soap has cardboard fillers. Cheaper soap has more fillers. Try a better soap brand.
    4: The washer may have build up inside and may need to be cleaned out. (not likely as this clears up real fast)
    Apr 03, 2010 | Washing Machines
    My Maytag washing machine leaves residue (lint? soap?) on clothes
    us liqwid soap us les chang filter.to meny close can trap the dry stuf.
    Jan 25, 2010 | Maytag PAV2300 Top Load Washer
    4268 iron leaving residue
    This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
    Aug 04, 2009 | Sunbeam Irons
    The Dryer heats up for a while and the stops heating after running for a while.
    Without the specific model number to work with, I'm taking a guess that your dryer has a sensor at the back of the drum. That is the dryness sensor that the clothes rub against and let's the dryer determine if the clothes are dry, according to the setting you selected on the control knob.
    First thing to do is use some Windex on a clean cloth to clean the senor strips as use of dryer softener sheets can leave a residue that builds up on the sensor and could be causing it to stop.
    The other thing you can do is use the timed dry cycle to see if the dryer works correctly. If the dryer works OK in the regular timed cycle, then it is possible you have a defective sensor.
    Without more information about your dryer, It is difficult to provide more possible diagnostic steps and provide you with a possible solution.
    Jul 28, 2009 | Whirlpool Dryers
    Bosch Exxcel WVT3250 Front Load Washer / Dryer Logo
    83 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
