This problem should be removed because:
Problem with Toshiba Projection Televisions
i switch my toshiba 50 inch rear projection tv on it makes a couple of clicking noises but does not come on
Suggested Solution (3)
take the back off and change the fuse
Source: toshiba 50"rear projection hometheater picture shut off on/off light flashing
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Source: my Toshiba 50 inch projection screen TV isnt displaying
One thing that comes to mind when you say high pitched sound is the HOT ( Horizontal Output Transistor). You may be able to find one at fry's electronics. They are pretty cheap. If you are handy and know something about electronics you may be able to replace it. I am not a TV tech, I have a background in electronics and like to play with them from time to time. Not sure this will help but good luck
cost to repair
hi i have a cracked screen on my tv and was wondering how much it would cost to fix thanks kurt
Theatre View Toshiba Rear Projection TV 50 Inch...
I have a Theatreview Rear Projection TV 50 Inch Toshiba Today I could not get it to power on- Each time I pointed the remote or attempted to...
my Toshiba 50 inch projection screen TV isnt...
just today my toshiba 50 inch projection TV started malfunctioning. when i turn it on i hear the activation noise and volume and see the red...
We have a old projection Tv made by Toshiba I
We have a old projection Tv made by Toshiba I think its 60 or 65 inch..got it back in 2000. It was HDTV compatible. A couple of weeks ago...
last night 6 days after
last night 6 days after we had direct tv installed, we had a power surge,and now our toshiba 50 inch rear projection tv has audio, but no...
Tips for Helping stokesay3310 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
toshiba 52hmx94 green screen
trying to use hdmi for ps3 it worked for a minute the other day, i can read and change menus so i don't think...
my RCA tv green power button flashes and beeps,...
2004 HD tv large box
I have a 50 Inch Toshiba DLP. The red light would...
I have a 50 Inch Toshiba DLP. The red light would come on and them blink and them turn itself off and start all over...
samsung dlp tv shutting down
After working well for a number of hours the TV shuts down and restarts then goes through the shut down restart sequence...
Fix-O-Meter
35
35 people viewed this problem
- 0 people are following this problem. Be the first!
Top Toshiba Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
