Question about Garmin nuvi 205W GPS Receiver
My Garmin nuvi 205w turns itself off. I switch it on, fully charged, and go through steps, first screen loading maps, press "agree" on next screen, picked address (recently found), map comes up with blinking red question mark on home location,with top banner "acquiring satellites" and within 2 mins. of starting, it turns itself off. How to correct, pls.
  • Garmin Expert
  • 343 Answers
Sounds like your battery is getting weak.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility probably at Garmin.com. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Posted on Feb 06, 2010
Up date map
In order to update your Garmin Nuvi 205W's system version, you'll need to download software which checks your unit's current version and updates it to the latest version. The current version available is 2.9.1.0 as of December, 2009. Garmin makes it easy by installing a browser plugin instead of having to install a software package. The WebUpdater plugin can be downloaded here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
In order to install the plugin you must first agree to the license agreement. You will then need to close all of your open browsers that are open on your computer to finish the install. Once you have, the plugin will start to install. To finish the system update, Garmin lists several steps on a page;
  • Disconnect your 205W from your laptop or desktop and let it restart
  • Once you see the main screen, you can connect it back to your computer and wait 30 seconds.
  • On the next screen, click the 'Find Devices' button and then click the 'Next' button.
Once your computer finds your 205W and you initiate the update, the plugin will install the new system to your unit.
Hope helps.
Apr 03, 2011 | Garmin nuvi 205W GPS Receiver
Tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205W GPS Receiver
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
How to Perform a Hard Reset of your Garmin Nuvi 205W
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
I hope that helps.
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi will not load maps - why
Try the Hard Reset procedure outlined in this tip.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 205w will not boot past the loading
Yes, it's a software bug and the only way to fix it is to RMA it to Garmin and they will send you a new one. Waitin on my replacement now.
Dec 22, 2009 | Garmin nuvi 205W GPS Receiver
Nuvi 205W keeps rebooting.
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
Jun 02, 2009 | Garmin nuvi 205W GPS Receiver
Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
Apr 17, 2009 | Garmin nuvi 205W GPS Receiver
NEW Garmin 205W Use of Apple Mac USB for charging Causes malfunct
Hold the power button to the left for approximately 15 seconds, then release it. It should reset the unit and turn ON. It happened to me before and it worked.
Dec 08, 2008 | Garmin nuvi 205W GPS Receiver
Error message appeared and can not do anything with it now
Here is the the lastest response:
Thank you for contacting Garmin International.
If you updated your nuvi 200, 200w, 205, or 205w to City Navigator North America NT 2010.10 between 4/7/09 and 4/25/09, and your unit is display the message, "No detailed maps found that support routing. The nuvi cannot be used without them." or "Can't unlock maps." A new revision of the 2010.10 update file (Garmin_RMU_CNNANT2010C.exe) has been released which corrects this issue. To download this new revision, please follow these steps:
1. Log into your myGarmin account
2. Click Manage Maps and Downloads
3. Connect the nuvi to your computer
4. Click Download Again next to your nuvi
5. Click Launch Download Manager
6. Follow the prompts to install the Download manager
7. Save the file to your Desktop
The new download may take a few hours to download. Once the file has fully downloaded, double click the file to run it, and follow the onscreen prompts to begin the installation again. You will now be able to choose the appropriate region for your device.
Note: Please make sure to only select the region that originally came loaded to your device. For example, if you have a nuvi 200 that came with the Lower 49 States, select that region and not a region that includes Canada.
With Best Regards,
Mark S
Senior Product Support Specialist
Automotive Team
913-397-8200
800-800-1020
Dec 01, 2008 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
906 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
