Question about Frigidaire FEF336BC Electric Kitchen Range
I have a Frigidaire stove model number fgf337asc oven burner willn't turn on
I have a frigidaire stove model number fgfl66afa
Posted on Nov 24, 2009
The left rear stove element went on High and would not turn off by controls, why? There was an F550 code that came earlier with the oven?
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Frigidaire gallery electric stove too hot
You will need to replace the burner switches for the burners that are not functioning correctly.
It also sounds like you have a problem with the OCU (oven control unit), this part is known to consumers as the clock.
Do a Google search for the model number and find a supplier for the parts. All three of these parts will easily cost over $300 all together.
Also the model number you listed in missing the last 2 letters. Locate the sticker which contains your model and serial number. This sticker will be on the oven frame when you open your bottom drawer.
Apr 05, 2013 | Frigidaire Gallery GLGF389G Kitchen Range
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FEF336BC Electric Kitchen Range Logo
417 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
