Question about Kodak EasyShare C913 Digital Camera
For some reason my camera has stop working, I change out the batteries and it still does not have power.
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 17, 2009
PowershotA2400is len cannot retract
Are you sure the battery still has enough power (even after charging) to let the lens motor do its job?
Are you sure there is no mechanical problem, you can see on the outside? Did anyone stop the lens, while it was coming out? Did anyone drop the camera, while the lens was out?
There cam be a lot of reasons, why a lens won't retract. Could be some force was used, also could be something just went wrong inside the camera. Like a gear that broke inside, or the motor stopped working. A contact failed and perhaps lots of other things.
If you already took out the battery, and reinserted it, and nothing changed, The only thing you than can do is after getting the battery out, is recharge the battery and then put it in.
If you have a spare battery, or you know anyone who has the same battery, try that battery. If nothing indicates a mechanical failure, and nothing helps, just contact the Canon Service Centre closest to you. First ask what a possible repair will cost. hen decide if you would like it repaired or you want a new camera.
New camera's are much better and cheaper than cameras last year.
Feb 15, 2014 | Canon PowerShot S410 / IXUS 430 Digital...
Will not power up
Hi, Please remove the Battery from the cameraand give a look inside the battery compartment. Use a spot light & makesure that place are clean , the battery connector pin are not bend , broken orrusted. After that insert the fully charged battery and try to turn on. If itsnot turn on then its confirm the camera internal power supply unit is faulty.For few reasons this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.2. Thepower supply transformer stops working & need to replacement.3. turnon button connection may disconnected.For the confirmation all you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. Thankyou
Aug 04, 2012 | Vivitar ViviCam 8025 Digital Camera
My Olympus fe just stopped working. I changed the batteries and that wasn't the problem. It will not turn on! The viewing window is dark, only the tiny light blinks.
you camera is turned on but the shutter seems not to open the reason you only see a dark screen. remove battery and press and hold power button for one min. reinsert battery and try again. if it still doesnt work it might require to be send to depot.
Sep 07, 2010 | Olympus FE-230 Digital Camera
The camera's battery died yesterday. I changed the batteries this morning and now I only get the green light to come on, but the light stays on when the camera is off as well
It sounds like your power on button may be stuck, if the ON indicator is always on. That may be the reason your battery was dead yesterday. Try reinstalling your batteries, checking carefully the positive and negative positions, and working your power button several times rapidly to see if it is stuck. If it is still showing a constant ON condition, try the following steps. With the batteries out of the camera, try a tiny bit of rubbing alcohol around the power switch, working the switch rapidly for a few seconds to see if that frees it. Replace the batteries with known fresh ones and try to power up the camera. That may fix your problem. If not, the camera will probably have to be repaired or replaced.
Mar 22, 2010 | HP Photosmart E327 Digital Camera
When we press the on/off button nothing happens. I have new batteries in it, I also have the cable plugged in. Nothing happens
I had the same issue...turned out to be the batteries not making contact... change the battery manufacturer to a known maker. The off brand stuff has dimension problems.
Feb 13, 2010 | Fuji FinePix A850 Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
Battery dies fast
There is no setting, that sounds just like a faulty Li ion rechargeable battery. Test the camera with alkaline batteries , if it works fine get a replacement rechargeable battery. Ensure that batteries are fully charged first.
Apr 16, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Nikon SB-800 Defect
Have you tried other batteries?
If one cell has died, there will be enough power to power up the flash, but not enough to charge it reasonably fast. It may also stop the other cells charging up properly if they are charged together. I've had this problem with poor quality rechargeables before. I think flashguns put pretty heavy demands on batteries.
Oct 23, 2007 | Nikon Speedlight SB-800 TTL Flash
My camera died for no reason!
most probably the camera must be fall down and some internal circuit is short circuited which is swiching off the camera. sangita
Apr 28, 2007 | Canon PowerShot A75 Digital Camera
Kodak EasyShare C913 Digital Camera Logo
96 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
