Question about Whirlpool Duet GHW9150P Front Load Washer
We have off and on leaks under washer does not matter what cycle it is in and does not happen every time any suggestions . we had a person come take a look he adjusted door but this did not fix.
  • 5,911 Answers
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
3. Check the drain pump and drain hose. If you notice any pooling of water in the cabinet it could be a loose drain hoses or a leaky pump.
4. Check the area under the wash tub. The tub consists of two halves bolted together with a seal in the middle. If the seal is leaking it may need to e replaced. NOTE: This is a labor intensive repair.
5. Check the right hand side of the wash tub for a small air dow hose. Sometimes this hose comes loose and starts leaking. This hose runs to the pressure switch and is what is used to sense the pressure differential in the wash tub. If this hose is leaking, you would have problems with the washer overflowing.
Posted on Nov 17, 2009
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Leaks water in spin cycle no matter the size of the load
If you lean the washer back and inspect under the washer you will find rubber hoses and that is what is leaking check that clamps are tight or hose is cracked replace and repair as needed
Nov 21, 2009 | Admiral AAV7000A
Front loading washer bangs and thumps during spin cycle
hi may i suggest you remove the top cover of machine and check the drum mountings(rubber) and the spring/s that are connected to the bracket on drum have not broken /come off just one other thing ? when machine was installed was the bracket under the top cover removed b4 connecting and using machine ? this bracket is for security/stability of drum whilst being transported see instruction book ? it is not the first time iv'e encountered this bracket not being removed by customer diy installation worth checking? best wishes
Oct 23, 2008 | Washing Machines
Maytag washer
dsands, if the noise is like a train roaring then it could be the bearing. The fact that you have some water leaking leads me to believe that the tub seal leaked onto the bearing. Now this could be covered under the 5 year warranty, depending on the tech that comes out. Another possiblility is that something is caught in the pump and it is leaking. You would have to open the front panel to get a look. On these Maytags if something gets in that pump like a button etc., they will scream like a raped ape. With out being there my gut feeling tells me the seals leaking and ruined the bearing. Catriver.
Dec 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Leaking from underneath washer
According to service manual, the drain motor is at the front, but the hose drains out the back. Possibly a leak in the drain hose?
Manual is at:
http://136.166.4.200/contents/Laundry/WM1814/WM1814_Service_Manual.pdf
Dec 02, 2007 | LG WM1812C Front Load Washer
Water leaking all over floor
Just a suggestion but it could be that the person who installed it did not seal the pipes properly, hence the leaking on your floor.
If you recheck these pipes to prevent further problems and see what happens.
Regards,
David
Nov 05, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
263 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
