Question about Sony PlayStation Portable (PSP) Console
I cant access the secret menus on my psp. Ive tried holding down the right top button on start up as well as the select button once it has started
  • 188 Answers
1) First of all, is your PSP 'hacked/chipped'? Only hack PSPs have 'Recovery Mode'... in your terms 'secret'!
2) If your PSP is hacked, is your R trigger functioning properly?
Yea... you'll need to hold the 'R trigger' down while turning on the PSP from startup (not from sleep mode).
Posted on Nov 18, 2009
  • 32 Answers
Hold down the right top button and once the psp is off u should turn it while is turning on presss the R1 button and the menu should be there
Posted on Nov 17, 2009
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Switch to english
Hi newagehippie,
on your PSP go to " settings " ( it looks like a tool box ) --> then " System Settings " ( it looks like a PSP ) --> then select your Language.
i hope this helps.
May 16, 2011 | Sony PlayStation Portable (PSP) Console
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
PSP turned on, black screen, cannot access recovery menu
Your psp screen may have broke you can buy a repair or get it fixed at ebay.com.Type in psp repair and you will see people will fix them for a low cost.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp umd reader spins and lazer activates and tries but no game/movie is recognized on screen
Download this Pandora Deluxe 1.2
And this 4.01 official firmware
Open the Pandora Deluxe 1.2 and install.
Unrar the 4.01 official firmware and place the EBOOT.PBP in a folder on your desktop named 4.01.
Connect your PSP and enable USB. Start the Pandora Deluxe 1.2 program, while it is starting it will ask you if a certain drive letter is your PSP, make sure it is correct and click ok.
Click on the "Load 4.01 firmware" button and it will ask for the location of it. Find the 4.01 folder on your desktop, double click it and it will show EBOOT.PBP, select it and clickk OK. Then check the install box next to it. In the colum to the right select "Despertar Cementerio v7 (4.01m33-2)". Now just below that in the center is a drop down box with DCv7 next to it, drop the box down and select LEFT. In the box right below it check Format + Prepare Memory Stick, If you need to backup your memory stick select it. Make sure that the PSP Drive letter is correct and when you are ready to start press START.
When the operation is complete, disable the USB, disconnect the PSP and turn off. Remove the battery. Hold down the LEFT Trigger while inserting the PANDORA battery and continue to hold until the menu comes up.
Select NAND operations, then IDStorage tools. In that follow the prompts on the screen. Select your region, then turn on wifi switch and pres x to Get Real Mac and continue on till finished.
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp will not load
start PSP while holding down the right button,
this will access bios,
use the 4 way button and the x button to scroll down to cpu speed,
select a higher cpu speed.
you may have to do this several times to get the cpu to the correct speed it was at beforeit stopped working,
i cant recal the correct cpu speed
Sep 19, 2008 | Computers & Internet
I forgot my password on psp hoe do i reset it
1. Take your Sony Playstation Portable (PSP) and hold the power switch for approximately 10 seconds.
2. After approximately 10 seconds the Sony PSP will shut off. Leave off for 30 seconds.
3. Flip your power button on your Sony PSP once, and in some cases twice. The Sony PSP will start up and should resume normal performance.
or
Disconnect the power cord / remove battery and hold down the power button.
Aug 11, 2008 | Sony PlayStation Portable (PSP) Console
Aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Feb 11, 2008 | Watches
The "home" button on my PSP does not work
I have the same problem.. I cant put YES on home and my R button isnt working either.. but I've noticed that if I push down the power button to the HOLD lvl and then put it again to the medium lvl it works like the R button -_-'' ..
Jan 06, 2008 | Sony PlayStation Portable (PSP) Console
Help my PSP
If not on hold then you may have to remove lid. by the screws under batt. and on side of PSP. Be very careful to not break anything, remember if it does not come off easy then there maybe another screw in place. Once open cleaned the pads that are beside home button and replace lid. Hope this helps
Aug 27, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
325 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
