Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
KUDS model clean light flashes
My Dishwasher's "clean" light flashes 7 times goes off for a few seconds and then repeats the process.
  • 5,911 Answers
This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Often, I have found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 17, 2009
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 30, 2009 | Whirlpool Dishwashers
Dishwasher won't start. Clean light keeps flashing. I have tried cancelling a couple of times, and it goes through a 2 minute process and goes right back to the flashing clean light and not allowing it to...
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 20, 2009 | Dishwashers
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
We have a kitchenaid dishwasher model#kud102irbl serial#FU1705420 Clean light keeps flashing on 7 times, waits a few seconds and flashes 7 times again. How can we repair this?? Dishwasher will not leave...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 26, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
224 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
