Question about Sewing Machines
I have a WEstinghouse dehumidifier and I want to vent it directly into the sink so that I don't have to empty it frequently. I don't know how to do this and can't find the hose outlet. It is MDFI 30AE. Is it possible to attach a hose to this machine and if so how?
  • 770 Answers
I have researched and found several small and inexpensive pumps that are designed to go into a dehumidifier resevoir. I am the guy that you had the chat session with yesterday. I can relate my info to you upon request. No need to re-open chat. If you are interested in what I have found, respond with your email address and I will forward results.
Hal
Posted on Nov 18, 2009
  • Hal Hallman Nov 18, 2009
    Also this type of pump has small tubing, such as what you would find on an aquarium pump but a little bigger than that. You can use clear tubing that would be inconspicuous.
  • Hal Hallman Nov 25, 2009
    I did a live chat with you on this issue recently. I thought we had solved the issue, but I see this morning that the chat was refunded. Curious, how did the problem get solved...what did you do to take care of your dehumidifier issue?
Hi. I have a Bernini 145. What is the best setting for a satin stitch? Thank you.
It will depend to a great degree on the thread that you use. Basically, you want a stitch length that does not allow fabric to show between the stitches but far enough apart so the stitches do not overlap.
Then there is the trick of keeping the stitch at a consistent 90 degree angle to the fabric edge. Whenever going around a curve, stop frequently with the needle down and slightly turn the fabric to keep that 90 degree angle. Also, be sure to sink the needle on the outside of the curve before turning the fabric. This possibly will cause the stitches to overlap on the inside of the curve so there will be no gap on the outside curve.
10 tips for satin stitch applique
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjp6p2S1_XSAhVO02MKHeweDRwQFggeMAE&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
How to Appliqu Like Pro Sew4Home
http://www.wwwearables.com/techniques/satin-stitch.htm
Mar 27, 2017 | Sewing Machines
Tip
Sewing Machine Needle Guide (Schmetz)
Want to know what sewing machine needle to use? Here's a handy guide.
http://www.schmetzneedles.com/learning/pdf/schmetz-needle-chart.pdf
Change your needles frequently. If you are experiencing problems with your stitch, the first thing to do is change out the needle. Needles get damaged and worn over time and are frequently the cause of stitching problems. Needles are the least expensive repair cost on your machine, so don't spare the expense!!!
on May 20, 2015 | Sewing Machines
My singer touch and sew is stuck. I can get it to go up and down twice and then the whole thing sticks and i have to turn the wheel with great difficulty
If I remember correctly, the Touch n Sew is an older mechanical machine. If so, most likely it has seized because the old oil has solidified and "glued" the moving parts together.
Pick up some liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Open the top, side, and bottom of the machine. Gently wiggle the handwheel and apply 1-2 drops each place where metal parts rub metal parts. Do NOT oil belts, synthetic, or plastic parts and do not over-oil! Then apply heated air from a handheld hairdryer directed into the internal mechanisms of the machine. Alternate oil and air, and hopefully after several treatments, it will move freely again.
Remember, like your automobile, mechanical machines need frequent oiling and cleaning. If using sewing machine oil, be sure it is Fresh, Good Quality sewing machine oil. If the machine is used frequently, oil every 40 hours of use. If not frequently used, oil every six months (even if in storage).
Oct 07, 2016 | Singer Sewing Machines
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
I need to order a power cord for a Singer 5530 with pedal I lost mine and I need it to sew my quilts
Try some online sewing machine parts suppliers:
http://www.sewingpartsonline.com/
Sewing Machine Parts
Try contacting Singer directly or check with the local sewing repair shop. Frequently, they can order the part for you.
Dec 11, 2015 | Singer Sewing Machines
After breaking a needle I cannot get my bobbin to catch. also can't find the piece of needle.
you may have knocked it out of time just a little . repair shops do not charge much to retime usually .
Oct 19, 2015 | Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
I need a manual for a free westinghouse sewing machine
Try www.sewing-machine-machine-manuals.com and click on relics and don't be put off by the word relics
Sep 19, 2011 | Sewing Machines
When I try to push on the pedal, I get only a beeping sound and no action. Can you advise on this situation?
Make sure that your bobbin is full, not empty or wound uneven. Go to singerco.com and see if it is listed in the frequently asked question or in the manual.
Sep 12, 2010 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
