Question about Canon CanoScan 8400F Film Scanner
My scans all have wide colored ghost lines of varied widths across the entire page. Do I need a new bulb and can that be done by myself?
  • 62 Answers
The bulb should be ok. See if the scan assembly moves as it should (even in speed and hieght).
Posted on Nov 17, 2009
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Dull colors on half the page
I would replace the transfer belt see if that makes a diffrence hope this helps
Nov 20, 2009 | HP Color LaserJet 2600n Printer
Hitachi 53SDX20B
Hi, common issue but difficult for lay person to fix, tube sockets and spark gaps on crt boards need to be cleaned, hard to get at but most local shops have probably done more than once, if you want to attempt get back to me & I`ll explain further, video-tek
Jun 09, 2009 | Hitachi 53SDX20B 53" Rear Projection...
Scanner gives poor quality scan...bulb?
I have one with the same problem. Look at the lamp. If it isn't really bright, that could be the cause. Mine is bright at one end and that is the side of the page that is good. I am not an expert so I could be wrong, but that is where to start if all else looks OK. Am looking for a cheap replacement lamp myself. But at the prices of all-in-ones, it's not worth spending much.
May 26, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Coloring is off and there is a ghosting effect
You have a convergence problem.You can replace this module cheaper than it can be repaired.It is so easy to do and electronics skill level is not required.If you can unplug the TV and remove the rear cover,then you can do this repair yourself.1 screw and 5 connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost to you.Good luck and please rate my information.
Jan 30, 2009 | Samsung HCN4226W 42" Rear Projection...
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Mar 24, 2017 | Samsung LN-S4695D 46 in. LCD HDTV
DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Mar 31, 2008 | Canon DR-5010C Path-Through Scanner
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Line down center of page.
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Dec 04, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon CanoScan 8400F Film Scanner Logo
127 people viewed this question
old marine
old marine
