Question about Dream Vision CINEXONE Multimedia Projector
Dream Vision CineXone projector
It was working just fine on Christmas now it won't even turn on
  • 17 Answers
SOURCE: Led indicator light is on
DC power supply may be defective, repair or replace.
Posted on Sep 30, 2010
0 characters
1 Points
When the unit start up its fine within 1 minute vertical lines show
you can have a colder joint in the circuit input. Try to clean from oxide, corrosion. and of course to reheat the solder.Test the cables for open or oxide too and clean with contacts spray cleaner.
Merry Christmas.
Dec 20, 2013 | Dream Vision DreamWeaver Multimedia...
It has vertical lines when it starts up
test the main PWB for colder joint and reheat 2) video signal en pwb faulty, test 3) test the cables for dusty, oxide, corrosion.
Merry Christmas.
LC-x50 has double vision or shadowing. What can cause this?
several reasons : 1.check cables, if too long and poor quality you get echoes in signal and shadows in the projected picture.
2.feed the right solution to the projector and adjust in menu pc adjustment the item FINE Sync. native resolution is 1024 x 768.
Jan 16, 2011 | Eiki LC-X50M Projector
Our Proxima DP5800 will not turn on with remote
First check the main switch located at the rear of the unit next to the power socket.Make sure it's turned on. Next, if the projector turns on with the power button on top of the unit, then the problem is with the remote. Replace batteries to make sure fresh ALKALINE batteries are installed correctly--the batteries must SAY alkaline on them. Ordinary carbon batteries WILL NOT WORK! Check inside the battery compartment for corrosion from a leaked battery. To actually test to see if a remote is working, you will need use of a camcorder with "night shot" or night vision capability. Turn on the camcorder and set it for night vision. From a distance of at least 8-10 feet, aim the remote at the camcorder and press a will see the front of the remote light up as if it were a flashlight! That is the infrared coded light the remote produces to signal the projector.If you don't see any light, the remote is bad and will have to be replaced. If you see light, the receiver on the projector is not functioning correctly and will have to be repaired.
Sep 04, 2009 | InFocus Proxima Remote Control for DP5800...
Unit will not turn on
Hello there:
this unit has a internal fuse that has probably blown and is in need of replacement if this doesent cure the problem i would contact the manufacturer of this unit for further repair suggestions. ok?
best regards michael
Aug 31, 2008 | Dream Vision DL 500 StarLight Multimedia...
Infocus projector x3 user manual
I had the same issue too. Dream Vision also makes the DL500 under different brand names.
Try the Kodak DP850 manual.
Jun 10, 2008 | Multimedia Projectors
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
HI there
Check that your power cable is ok. Best way is by trying a differnt cable. If the problem still shows , you might have to open it up check if the fuse on the powersupply board is ok and then worst case cenario have the powersupply replaced.
Hope this is of help !
May 25, 2007 | Sanyo PLC XU30 Multimedia Projector
Multimedia Projectors Logo
49 people viewed this question
Top Dream Vision Multimedia Projectors Experts
Electro Med Services...
Are you a Dream Vision Multimedia Projector Expert? Answer questions, earn points and help others
