Question about Square D Qob120 1pole 20amp 120v Circuit Breaker
What is the maximum amount of electrical energy that can be delivered durning a short circuit for low voltage 230v/400v
    President:
  • 704 Answers
Tom, Not sure if what you're asking relates to the Maximum electrical energy (Voltage and Amps) that can occur during a short circuit through a properly protected electrical circuit (protected by a circuit breaker, etc.) or if the question is for the maximum amount you could potentially get from a short circuit on a 230V or 400V electrical line to ground OR another electrical line/supply.
IF the circuit is a 230V-AC circuit protected by a double circuit breaker, you could see the entire Voltage (230V-AC) and up to the full Ampere rating of the circuit breaker, (20, 30, 40, 50, etc Amps) during a short circuit condition to Ground.
IF the circuit is a 400V-AC circuit protected by a double circuit breaker, you, again, could get the entire Voltage (400V-AC) and up to the full Ampere rating of the circuit breaker protecting the circuit, when shorted to Ground.
Now, IF the short condition involves one of the above line voltages AND you are having it shorted against another Voltage/Amp circuit, the total potential Voltage and Amps you could experience, would basically be the sum of the two Voltages (and Amps) of the two (2) circuits being put into a short condition. So you would/could see a potential short circuit of whatever voltage is available, depending on what and where the short circuit is occurring.
By way of example, I've seen a 240V-AC 60 Amp circuit shorted to another 240V-AC 60 Amp circuit and the resultant "short condition caused enough damage, due to the voltage and Amps provided, to melt and weld the machinery's electrical connections, rendering the unit a total loss, not to mention that the person that caused the short to occur, received a face-full of melted copper metal bits all over their face and body. Thankfully they were wearing safety glasses, and their eyesight was saved, albeit, with some temporary blindness caused by the extremely bright flash and explosion.
The examples provided assume a properly working/functioning circuit breaker protection. However, if the circuit breakers are faulty, it is possible to recieve much higher vlotages and Amps, since there would be no protective circuit breaker that could trip the power off. In that case, the Main circuit breaker becomes the fail-safe protective device and that could have a much higher Amp rating, thus the maximum Voltage/Amps would be limited by the Main electrical ciruit breaker and electrical supply available at the location where the short circuit occurs.
This could be MUCH higher Voltage and extremely high Amps, depending on the situation and equipment involved.
If you have more information about the particular situation, please post a follow-up comment and I'll provide you with some more info.
I hope you find this Very Helpful and best regards!
Posted on Nov 17, 2009
I have old carrier 50zp060511s Air Conditioners that having voltage details like 3ph 220V 60hz UL Standard But now i have voltage of 400V 3ph & 230V 1ph.. is there any solution for this issue..
If you are reading 400 volts coming into the unit, call electric company. You should only have 220-240 from your power lines. Anything over that will burn out unit. P.S. In my opinion Carrier Units are the best and longest lasting when properly maintained.
May 08, 2016 | Carrier Heating & Cooling
I am getting the following codes on my 2002 Nissan Altima v6 3.5 liter P1430, P1420, P1805, P1152, P1102, P1011, P1021 & P1335 I'm going crazy here. Please help!
Definition of Diagnostic Trouble Code P1430 Ford: Electric Air Pump Secondary Lincoln: Electric Air Pump Secondary Mazda: Electric Air Pump Secondary Mercury: Electric Air Pump Secondary Toyota: Intake Constrictor CTRL Circuit Open or Short
Definition of Diagnostic Trouble Code P1420 Audi: Second Air Injection Valve Circ Electrical Malfunction BMW: Secondary Air Valve Control Circuit Electrical Buick: Intake Air Low Pressure Switch Circuit Low Voltage Cadillac: Intake Air Low Pressure Switch Circuit Low Voltage Chevrolet: Intake Air Low Pressure Switch Circuit Low Voltage Chrysler: Register Resonant Charging 1 (RRC1) Dodge: Register Resonant Charging 1 (RRC1) Ford: Catalyst Temperature Sensor GMC: Intake Air Low Pressure Switch Circuit Low Voltage Honda: Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter Jeep: Register Resonant Charging 1 (RRC1) Lincoln: Catalyst Temperature Sensor Mazda: Catalyst system efficiency below threshold (bank 1) Mercedes: AIR Pump Switch over Valve Mercury: Catalyst Temperature Sensor Oldsmobile: Intake Air Low Pressure Switch Circuit Low Voltage Pontiac: Intake Air Low Pressure Switch Circuit Low Voltage Saturn: Intake Air Low Pressure Switch Circuit Low Voltage Subaru: EVAP Purge Control Solenoid Circuit High Input Toyota: SCV Control Circuit Malfunction Volkswagen: Second Air Injection Valve Circ Electrical Malfunction
Definition of Diagnostic Trouble Code P1805 Ford: Four wheel drive high indicator circuit failure Lincoln: Four wheel drive high indicator circuit failure Mazda: (4WD) High Indicator Open Circuit Mercury: Four wheel drive high indicator circuit failure Toyota: SB Solenoid Circuit Malfunction
Definition of Diagnostic Trouble Code P1152 Audi: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Jaguar: Lack of H02S-21 switch, sensor indicates rich Land Rover: Oxygen sensor response time bank 2.Short circuit to ground Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Subaru: Oxygen sensor range /performance problem (Low) Volkswagen: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded Volvo: Oxygen Sensor Front, Bank 2
Definition of Diagnostic Trouble Code P1102 Acura: Mass Airflow (MAF) Sensor Lower Than Expected Comprehensive Audi: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Chrysler: HEV Stop Request Performance Dodge: HEV Stop Request Performance Hyundai: MAP Sensor Circuit Low Input Jeep: HEV Stop Request Performance Kia: Heated Oxygen Sensor Bank 1 Sensor 1 Heater Circuit High Input Land Rover: Throttle to air flow plausibility not active.Last occurrence - minimum signal Mazda: Mass Air Flow Sensor In Range But Lower Than Expected Mitsubishi: Traction Control Ventilation Solenoid Circuit Porsche: Heated Oxygen Sensor 1 Ahead Of TWC Heater Short To B+ Saab: Front Heated Oxygen Sensor Bank 1, Control Module Input, Current in Pre-Heating Circuit Too High Subaru: Pressure Sources Switching Solenoid Valve Circuit Malfunction Volkswagen: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Volvo: Power Stage Group B
Definition of Diagnostic Trouble Code P1011 Saab: Injector Cylinder 1 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 1)
Definition of Diagnostic Trouble Code P1021 Honda: Valve Pause System Stuck On Comprehensive Mitsubishi: OCV OPN. Bank 1 Saab: Injector Cylinder 2 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 2)
Definition of Diagnostic Trouble Code P1335 Audi: Engine Torque Monitoring 2 Control Limit Exceeded Buick: CKP Circuit Cadillac: CKP Circuit Chevrolet: CKP Circuit Ford: (EGR) Position Sensor Minimum Stop Performance GMC: CKP Circuit Infiniti: CKP Sensor (Ref) Jaguar: CKPS Circuit Malfunction Land Rover: Exhaust gas recirculation position sensor minimum stop performance. Lexus: Igniter Circuit Malfunction Bank 2 (During Engine Running) Lincoln: (EGR) Position Sensor Minimum Stop Performance Mazda: (EGR) Position Sensor Minimum Stop Performance Mercedes: CKP Sensor Circuit Malfunction, Bank 2 Mercury: (EGR) Position Sensor Minimum Stop Performance Oldsmobile: CKP Circuit Pontiac: CKP Circuit Saturn: CKP Circuit Toyota: No CKP Sensor Signal Engine Running Volkswagen: Engine Torque Monitoring 2 Control Limit Exceeded http://www.obd-codes.com/trouble_codes/nissan
Jun 29, 2015 | Nissan Cars & Trucks
TROUBLE CODE P 1613 IN WV PASSAT 99
P1102O2S Heating Circuit Bank 1 Sensor 1 Voltage Too Low/Air Leak
P1105O2S Heating Circuit Bank 1 Sensor 2 Short To Positive P1107O2S Heating Circuit Bank 2 Sensor 1 Short To Positive P1110O2S Heating Circuit Bank 2 Sensor 2 Short To Positive P1113O2S Sensor Heater Resistance Too High Bank 1 Sensor 1 P1115O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 1
P1116O2S Sensor Heater Circuit Open Bank 1 Sensor 1
P1117O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2
P1118O2S Sensor Heater Circuit Open Bank 1 Sensor 2
P1127Long Term Fuel Trim B1 System Too Rich
P1128Long Term Fuel Trim B1 System Too Lean
P1129Long Term Fuel Trim B2 System Too Rich
P1130Long Term Fuel Trim B2 System Too Lean
P1136Long Term Fuel Trim Add. Fuel B1 System Too Lean
P1137Long Term Fuel Trim Add. Fuel B1 System Too Rich
P1138Long Term Fuel Trim Add. Fuel B2 System Too Lean
P1139Long Term Fuel Trim Add. Fuel B2 System Too Rich
P1141Load Calculation Cross Check Range/Performance
P1144Mass Air Flow Sensor Open/Short To Ground.
P1145Mass Air Flow Sensor Short To Positive.
P1146Mass Air Flow Sensor Supply Voltage.
P1155Manifold Absolute Pressure Sensor Short To Positive.
P1156Manifold Absolute Pressure Sensor Open/Short To Ground. P1157Manifold Absolute Pressure Sensor Supply Voltage.
P1160Intake Air Temperature Sensor Short To Ground.
P1161Intake Air Temperature Sensor Open/Short To Positive. P1162Intake Air Temperature Sensor Short To Ground.
P1163Fuel Temperature Sensor Open/Short To Positive.
P1164Fuel Temperature Sensor Implausible Signal.
P1171Throttle Actuation Potentiometer Sign. 2 Range/Performance P1172Throttle Actuation Potentiometer Sign. 2 Signal Too Low P1173Throttle Actuation Potentiometer Sign. 2 Signal Too High P1176Rear O2S Correction
P1177O2 Correction Behind Catalyst B1 Limit Attained
P1196O2S Heater Circuit Bank 1 Sensor 1 Electrical Malfunction P1197O2S Heater Circuit Bank 2 Sensor 1 Electrical Malfunction P1198O2S Heater Circuit Bank 1 Sensor 2 Electrical Malfunction P1199O2S Heater Circuit Bank 2 Sensor 2 Electrical Malfunction P1213Injector Circuit Cylinder 1 Short To Positive
P1214Injector Circuit Cylinder 2 Short To Positive
P1215Injector Circuit Cylinder 3 Short To Positive
P1216Injector Circuit Cylinder 4 Short To Positive
P1217Injector Circuit Cylinder 5 Short To Positive
P1218Injector Circuit Cylinder 6 Short To Positive
P1225Injector Circuit Cylinder 1 Short To Ground
P1226Injector Circuit Cylinder 2 Short To Ground
P1227Injector Circuit Cylinder 3 Short To Ground
P1228Injector Circuit Cylinder 4 Short To Ground
P1229Injector Circuit Cylinder 5 Short To Ground
P1230Injector Circuit Cylinder 6 Short To Ground
P1237Injector Circuit Open Cylinder 1
P1238Injector Circuit Open Cylinder 2
P1239Injector Circuit Open Cylinder 3
P1240Injector Circuit Open Cylinder 4
P1241Injector Circuit Open Cylinder 5
P1242Injector Circuit Open Cylinder 6
P1245Needle Lift Sensor Short To Ground
P1246Needle Lift Implausible Signal
P1247Needle Lift Sensor Open/Short To Positive
P1248Start Of Cold Start Injector Control Difference
P1251Start Of Cold Start Injector Short To Positive
P1252Start Of Cold Start Injector Open/Short To Ground
P1255Engine Coolant Temperature Sensor Short To Ground
P1256Engine Coolant Temperature Sensor Open/Short To Positive P1300Misfire Detected, Fuel Level Too Low
P1250Fuel Level Too Low P1325Cyl. 1 Knock Control Limit Attained
P1326Cyl. 2 Knock Control Limit Attained
P1327Cyl. 3 Knock Control Limit Attained
P1328Cyl. 4 Knock Control Limit Attained
P1329Cyl. 5 Knock Control Limit Attained
P1330Cyl. 6 Knock Control Limit Attained
P1336Engine Torque Adaption At Limit
P1337CMP Sensor Bank 1 Short To Ground
P1338CMP Sensor Bank 1 Open Circuit Or Short To Positive P1340CKP/CMP Sensor Signals Out Of Sequence
P1341Ignition Coil Output Stage 1 Short To Ground
P1343Ignition Coil Output Stage 2 Short To Ground
P1345Ignition Coil Output Stage 3 Short To Ground
P1354Modulating Piston Displacement Sensor Electrical Circuit Malfunction
P1386Internal Control Module Knock Control Error
P1387Control Unit Internal Altitude Sensor
P1391CMP Sensor Bank 2 Short To Ground
P1392CMP Sensor Bank 2 Open Circuit/Short To Positive
P1393Ignition Coil Power Output Stage 1 Malfunction
P1394Ignition Coil Power Output Stage 2 Malfunction
P1395Ignition Coil Power Output Stage 3 Malfunction
P1401EGR Valve Power Stage Short To Ground
P1402EGR Vacuum Regulator Solenoid Valve Short To Positive P1403EGR System Control Difference
P1407EGR Temperature Sensor Signal Too Low
P1408EGR Temperature Sensor Signal Too High
P1410Tank Ventilation Valve Circuit Short To B+ P1420Secondary Air Injection Control Module Electrical Malfunction P1421Secondary Air Injection Valve Circuit Short To Ground P1422Secondary Air Injection Valve Circuit Short To B+ P1424Secondary Air Injection System Bank 1 Leak Detected P1425Tank Ventilation Valve Short To Ground P1426Tank Ventilation Valve Open Circuit P1432Secondary Air Injection Valve Open P1433Secondary Air Injection Pump Relay Circuit Open P1434Secondary Air Injection Pump Relay Circuit Short To Positive P1435Secondary Air Injection Pump Relay Circuit Short To Ground P1436Secondary Air Injection Pump Relay Circuit Electrical Malfunction P1440EGR Valve Power Stage Open P1441EGR Vacuum Regulator Solenoid Valve Open/Short To Ground P1450Secondary Air Injection System Circuit Short To Positive P1451Secondary Air Injection Circuit Short To Ground P1452Secondary Air Injection System Circuit Open P1471EVAP Control System LDP Circuit Short to Positive P1472EVAP Control System LDP Circuit Short To Ground P1473EVAP Control System LDP Open Circuit P1475EVAP Control System LDP Malfunction/Signal Circuit Open P1476EVAP Control System LDP Malfunction/Insufficient Vacuum P1477EVAP Control System LDP Malfunction P1478EVAP Control System LDP Clamped Tube Detected P1500Fuel Pump Relay Electrical Circuit Malfunction P1501Fuel Pump Relay Circuit Short To Ground P1502Fuel Pump Relay Circuit Short To Positive P1505Closed Throttle Position Does Not Close/Open Circuit P1506Closed Throttle Position Switch Does Not Open./Short To Ground P1512Intake Manifold Changeover Valve Circuit Short To Positive P1515Intake Manifold Changeover Valve Circuit Short To Ground P1516Intake Manifold Changeover Valve Circuit Open P1519Intake Camshaft Control Bank 1 Malfunction P1522Intake Camshaft Control Bank 2 Malfunction P1537Fuel Cut-off Valve Incorrect Function P1538Fuel Cut-off Valve Open/Short To Ground P1539Clutch Pedal Switch Signal Fault P1540VSS Signal Too High P1541Fuel Pump Relay Circuit Open P1542Throttle Actuation Potentiometer Range/Performance P1543Throttle Actuation Potentiometer Signal Too Low P1544Throttle Actuation Potentiometer Signal Too High
P1545Throttle Position Control Malfunction P1546Wastegate Bypass Regulator Valve Short To Positive P1547Wastegate Bypass Regulator Valve Short To Ground P1548Wastegate Bypass Regulator Valve Open P1549Wastegate Bypass Regulator Valve Open/Short To Ground P1550Charge Pressure Control Difference P1555Charge Pressure Upper Limit Exceeded P1556Charge Pressure Negative Deviation P1557Charge Pressure Positive Deviation P1558Throttle Actuator Electrical Malfunction P1559Idle Speed Control Throttle Position Adaption Malfunction P1560Maximum Engine Speed Exceeded P1561Quantity Adjuster Control Difference P1562Quantity Adjuster Upper Stop Value P1563Quantity Adjuster Lower Stop Value P1564Idle Speed Control Throttle Position Low Voltage During Adaption P1565Idle Speed Control Throttle Position Lower Limit Not Obtained P1568Idle Speed Control Throttle Position Mechanical Malfunction P1569Switch For CCS Signal Faulty P1580Throttle Actuator B1 Malfunction P1582Idle Adaptation At Limit P1600Power Supply Terminal No. 15 Low Voltage P1602Power Supply Terminal No. 30 Low Voltage P1603Internal Control Module Self Check P1606Rough Road Spec. Engine Torque ABS-ECU Electrical Malfunction P1611MIL Call-Up Circuit/TCM Short To Ground P1612Engine Control Module Incorrect Coding
P1613MIL Call-Up Circuit Open/Short To Positive P1616Glow Plug Indicator Lamp Short To Positive P1617Glow Plug Indicator Lamp Open/Short To Ground P1618Glow Plug Relay Short To Positive P1619Glow Plug Relay Open/Short To Ground P1624MIL Request Signal Active P1626Data Bus Drive Missing Command From M/T P1630Accelerator Pedal Position Sensor 1 Signal Too Low P1631Accelerator Pedal Position Sensor 1 Signal Too High P1632Accelerator Pedal Position Sensor 1/2 Supply Voltage P1633Accelerator Pedal Position Sensor 2 Signal Too Low P1634Accelerator Pedal Position Sensor 2 Signal Too High P1639Accelerator Pedal Position Sensor 1/2 Range Performance P1640Internal Control Module (EEPROM) Error P1648CAN-Bus System Component Failure P1649Data Bus Powertrain Missing Message From Brake Controller P1676Drive By Wire MIL Circuit Electrical Malfunction P1677Drive By Wire MIL Circuit Short To Positive P1678Drive By Wire MIL Circuit Short To Ground P1679Drive By Wire MIL Circuit Open Circuit P1681Control Module Programming Not Finished P1686Control Unit Error, Programming Error P1690MIL Malfunction P1691MIL Open Circuit P1692MIL Short To Ground P1693MIL Short To Positive P1778Solenoid EV7 Electrical Malfunction P1780Engine Intervention Readable P1851Data Bus Drive Missing Command From ABS P1854Drive Train CAN-Bus Inoperative
Read more at: https://www.obd-codes.com/trouble_codes/volkswagen/
Copyright OBD-Codes.com
Apr 03, 2012 | Volkswagen Passat Cars & Trucks
I have 2002 Ford Expedition and it is running rough. had diagnostic test done and was given several codes. don't have manual to see what these codes mean. I was given 9 different codes. P0755, 1747,...
For each code there is a diagnostic testing procedure . Without doing the testing we would only be guessing as to the problem . Sounds like you know next to nothing about automobile engine management systems . Your best bet ,take it to a qualified repair shop .
P0443 - EVAP Control System Canister Purge Valve Circuit Malfunction The PCM monitors the state of the EVAP canister purge valve circuit output driver. The test fails when the signal moves outside the minimum or maximum limit for the commanded state.
  • VPWR circuit open
  • EVAP canister purge valve circuit shorted to GND
  • Damaged EVAP canister purge valve
  • EVAP canister purge valve circuit open
  • EVAP canister purge valve circuit shorted to VPWR
  • Damaged PCM
To verify normal function, monitor the EVAP canister purge valve signal PID EVAPPDC (or EVMV for electronic valve) and the signal voltage (PCM control side). With the valve closed, EVAPPDC will indicate 0 percent duty cycle (0 mA for EVMV) and the voltage approximately equal to battery voltage. When the valve is commanded fully open, EVAPPDC will indicate 100 percent duty cycle (1000mA for EVMV) and a voltage drop of 3 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function.
P0135 - HO2S Sensor Circuit Malfunction (HO2S-11) During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected.
  • Short to VPWR in harness or HO2S.
  • Water in harness connector.
  • Open VPWR circuit.
  • Open GND circuit.
  • Low battery voltage.
  • Corrosion or poor mating terminals and wiring
  • Damaged HO2S heater.
  • Damaged PCM.
  • Wiring.
  • Damaged PCM.
P0155 - HO2S Sensor Circuit Malfunction (HO2S-21) See DTC P0135
P0755 * SSB, wiring, PCM SSB solenoid circuit failure SSB circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. Incorrect gear selection depending on condition mode and manual lever position. See Solenoid On/Off Chart. Go To Pinpoint Test A .
P1747 * EPC, wiring, PCM EPC solenoid circuit failure, shorted circuit or output driver Voltage through EPC solenoid is checked. An error will be noted if tolerance is exceeded. Short circuit causes minimum EPC pressure (minimum capacity) and limits engine torque (alternate firm). Go To Pinpoint Test D .
P1401 - DPF EGR Sensor Circuit High Voltage Detected The EGR monitor checks the DPF EGR sensor signal to the PCM for high voltage. The test fails when the average voltage to the PCM goes to a voltage greater than the maximum calibrated value.
  • DPF EGR circuit open
  • VREF short to PWR
  • Damaged DPF EGR sensor
  • DPFEGR circuit short to PWR
  • SIG RTN circuit open
  • Damaged PCM
A DPF EGR PID reading greater than 4.5 volts with the key ON and engine OFF or running, indicates a hard fault.
P1451 - EVAP Control System Canister Vent Solenoid Circuit Malfunction Monitors the canister vent (CV) solenoid circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified canister vent duty cycle by PCM command.
  • VPWR circuit open
  • CV solenoid circuit shorted to PWR GND or CHASSIS GND
  • Damaged CV solenoid
  • CV solenoid circuit open
  • CV solenoid circuit shorted to VPWR
  • Damaged PCM
To verify normal function, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV will indicate 0 percent duty cycle and the voltage approximately equal to battery voltage. When the valve is commanded fully closed, EVAPCV will indicate 100% duty cycle and a voltage drop of 4 volts minimum is normal. Output test mode may be used to switch output ON/OFF to verify function.
Look's like you have multiple problems an to say what the problem could be would be guessing . Your best bet ,take it to a qualified repair shop .
Oct 17, 2017 | 2001 Ford Expedition
I have a kitchen aid electric range kesc307hbs8. we lost electricity one day and when it went back on the stove began to smell burTt. the range heats up but the control panel and touch pad are not working....
Hi.It is advisable to turn off your fuse or appliance when there is a power outage..When the power turns back ,it will produce surge amount of voltage that would eventually damage your appliances.when power comes back it has a very abnormal current flow.it may rise or fall which might beyond the wires capability.meaning it goes beyond what the wire can carry..It might be that when the power supply return it gives high current and short circuit the ground and live wires of your electric range.You better check continuity using an OHMETER.MULTITESTER if there is no short circuit.If the reading of the multitester if set to ohms is too high thats beyond the maximum amount going to the right,then there is a short circuit..
Jun 28, 2011 | KitchenAid KESC307 Electric Kitchen Range
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have bought aircooler with 115 watt and 230 V to my home. I am residing in a flat system in Delhi. The question is whenever the power line goes off, our home is provided electricity supply with power...
As long as the power supply delivers 230 V and AC- alternating current, which I guess the cooler runs with, there should be no problem using the cooler. You might need to check how much power(= amount of watts) the power system delivers. 115 w is not extremely high power consuption. It is 10 times less than a hair dryer, tostaer or similar.
Power backup systems often have less power and often are aimed to just supply enough power to keep the most important equipment running. An overloaded power supply will deliver lower voltage. Too low voltage might in many cases harm electical equipment, especially if used over longer times.
If the backup system is only battery based it may be good to use less energy consuming equipment to extend the backup time. Most likely is the backup system based on diesel engines in larger building complexes. They are normally dimensioned to supply regular consumtione used in the building.
Check how much power (=watt) you can use from the power supply, or is allowed to use from the landlord/service technician.
Summary:
Check that 230 voltage and AC is delivered. Then you can use the cooler.
Keep cool
/zeb0zeb0
May 13, 2011 | Kitchen Ranges
Hello, I had my car hooked up to a computer today and the codes P102, P0113, and P111 came up. The engine misses when driving down the road, and the car frequently dies when turning corners and idling. ...
P0113 Intake Air Temperature (IAT) Circuit High Input Indicates the sensor signal is greater than Self-Test maximum. The IAT sensor maximum is 4.6 volts or -50 C (-58 F). Possible causes are Open circuit in harness, Sensor signal short to power, Damaged Sensor, Improper harness connection, Damaged PCM
P0102 Mas Air Flow (MAF) Circuit Low Input, The MAF sensor circuit is monitored by the PCM for low air flow (or voltage) input through the comprehensive component monitor (CCM) If during key ON engine running the air flow (or voltage) changes below a minimum calibrated limit, the test fails. Possible causes are MAF sensor disconnected, MAF circuit open to PCM, VPWRopen to MAFsensor, PWR GND open to MAF sensor, MAF RTN cirbuit open to PCM, MAF circuit shorted to GND, Intake air leak (near MAF sensor), A closed throttle indication, Damaged MAF sensor, Damaged PCM.
Mar 18, 2011 | Buick LeSabre Cars & Trucks
What is the difference between electrical and electronics?
HI,
One view point is that "Electrical" relates to the development and delivery of the electrical energy to the various devices that perform specific functions in a given environment. Example: The alternator in your car that series of wires delivers electrical power / energy to various components (radio, the computer that monitors / controls operation of the engine) in todays cars.
Where as "Electronics" relates more to the complex functions performed within a given device, more often now days by circuits comprised of many micro electronic sub components that make up the structure of a single micro electronic component. Example: a typical CPU chip would / could contain thousands of individual transistor circuits within a device no bigger that the size of your small finger nail with room to spare.
GOODLUCK
Jan 12, 2011 | Computers & Internet
Nikon SB800 flash
sb-800 trigger voltage is very low.....around 8 volts.
Jul 22, 2008 | Nikon Speedlight SB-800 TTL Flash
Square D Qob120 1pole 20amp 120v Circuit Breaker Logo
138 people viewed this question
Top Square Electrical Supplies Experts
Jim D
Level 1 Expert
ken skalski
JOHN LAPIER
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
