Question about Garmin iQue 3600 GPS Receiver
Power problems My system turned off and it won't turn back on even with the charger plugged in...I was just wondering what I could do?
Did you try a soft reset??
Posted on Jan 19, 2008
I have a samsung STM330 tablet it has charged but won`t turn on.
  • Defective battery
  • Defective charger
  • Defective power switch
May 13, 2018 | Samsung Computers & Internet
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My HP Mini 210 1081NR Won't Turn On?
you have a motherboard problem.
Jul 20, 2012 | Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
My kindle does not to turn on when i slide the power switch
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 22, 2011 | Amazon Kindle 3G
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Oct 29, 2009 | Toshiba Satellite A305D-S6848 Notebook
I left my Compaq 2510p on standby with the battery low a couple of hours ago. I have now connected it to the mains charger and tried to turn the machine back on, but it won't turn on...any ideas what I...
Might be stuck in hibernation. Pull the battery and ac power for about 1 hour. Replace and try to boot. If fails, pull the battery and try to boot just off ac power.
Dec 01, 2008 | HP Computers & Internet
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
Garmin iQue 3600 GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
