Question about Sharp Office Equipment & Supplies
Sharp AL 1631 Black and White Copier it powers on than it gaves me ERROR L1. what it could be, Rollers for paper pickup looks good gears looks good
  • 17,970 Answers
On this machine there is a scanner lock which you can turn by mistake which creates the scan code L1; locate the the scanner locking knob and turn it back or better still remove it completely, this should get rid of your problem.
L1 = problem with the scanner.
Check the lock... beneath where the copy comes out but left it up. It is a transparent plastic wheel, is lock of the scanner.
Log in simulation "Clear" "Exp automatic" "Clear" "Exp Automatic" enters 24 Start 7 this operation reset the cylinder.
SP20-1 = reset
maintenance
Success.
Posted on Nov 17, 2009
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
FEED ROLLER Sharp AL-1631
Percision roller phx arizona also have web sight
Dec 26, 2008 | Sharp AL 1631 Copier
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
20 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
