Question about Dishwashers
Bosch dishwasher will not fill up after replacing sink faucet
I just installed a new kitchen sind faucet and now my dish washer will not fill up with water, it just makes a humming noise, please help
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Feb 20, 2008
  • 4 Answers
SOURCE: Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Posted on Feb 22, 2009
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
  • 2605 Answers
SOURCE: bosch shu9915uc dishwasher when turned
Welcome to FixYa.
Based on your description "dishwasher when turned on sounds like drain pump is running but water will not enter dishwasher" , it sounds like the emergency overfill switch has been actuated. Here`s what to do and what to look for.
**Turn off the breaker/power at your homes service first of course**
Remove the the bottom panel, referred to as a toe panel or kick-plate, essentially the lower service panel shown here...
When you remove the outer toe panel, there will be another small panel which is non finished steel, I find removing that allows much easier access as well.
This panel can be somewhat more difficult as it secures the plastic channeling for the wires but if you observe closely you`ll see it does "snap" out of place...carefully.
Once the panel has been removed check for any obvious signs of water in the base ( the unit has a plastic overfill basin with a float which will actuate an emergency overfill cycle, hence the drain pump runs & runs )
If you don`t see any water in this area, direct your attention to the left in this basin/bottom ( from the front to be sure ) and you should see a device which will resemble a "stir stick" you`d use for coffee etc. it will be a red in color stick.
With the aid of a wooden spoon, long screwdriver, or if you can manage to reach by hand, lift it up and down gently and listen for a "click".
If there is no sign of water and you can here the "click" when lifting up and down the float actuater ( red stick ) then turn the machine back on and give it a try before reassembling the toe panel so you can observe for any possible leaks.
Let me know what you find. This is the most likely cause of the symptom you are describing so we can move forward if this doesn`t resolve the issue.
Thanks for choosing FixYa. Good luck.
Macmarkus :)
Posted on Dec 30, 2010
0 characters
1 Points
Water at dish washer is not hot but water @ sink is hot. (right next to DW)
the dishwasher is normally on cold fill only and heats up water during wash cycle they can be connected to hot but is not recommended.
May 08, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Cloudy residue
the modern dishwashers dont use as much water as the older ones did,most common problem is the water temp. its a good practice to run your sink fauset in your kitchen until the water gets hot then start the dishwasher. now when it fills the water is hot at first fill! good luck!
Jan 26, 2010 | GE Dishwashers
Incomplete draining of water
Check if the outlet hose is clogged by disconnecting the tail end that is connected to the garbage disposal unit or kitchen sink. You should also unscrew and check the filter on the bottom pan of the dish washer and remove any food particles etc.
Sep 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fills with water when running faucet
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Jan 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher problems
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at
Mar 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dirty Dishes after dishwasher has finished
You may be getting sand in from the supply lines. Fill a clear glass container from the sink a few times and look at the bottom for sand particles. You may be getting sand from a pool filter? Remove the filter from the faucet head (it should unscrew) and look for sand particles in it. You may not be getting them in the kitchen sink if the dishwater inlets are below the sink as the particles may be sinking to the bottom of the pipes. You may need to put a filter in the dishwasher inlet. Try filling the dishwasher by hand with bottled water once and then see if the sand is still there. If so, it probably comes in through the water supply.
Nov 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishes not getting clean
when your dishwasher was reinstalled was the discharge hose loop up high behind dishwasher to prevent the water from draining? Also make sure that there is air gap where the hose ties into the drain.
Nov 22, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
