Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Water will not come through my dispenser on my refrigerator, it is not frozen in the lines cause i checked this. It worked when i first hooked it up.
  • 612 Answers
Without the model number I will only be able to tell you what makes most models work. When you push the lever for water, there is a micro-switch behind it that's activated. This sends a signal to the water valve at the lower back of your unit. It opens and allows water to flow. There is one connection between the micro-switch and the valve. It's located at the door hinge. It could be either the top one or the bottom. Make sue it's plugged in real good. While pushing the water lever, wiggle the plug. If it makes water come out, disconnect the plug and re-connect. If no difference, I would say the most likely problem is the water valve at the back of the fridge. You can apply 110 volts to the side that had the larger tube (On most, this is the valve for the water in door) When you connect 110 to it, if water comes out on the door, you have a bad micro-switch. If no water, you have a bad water valve. You will need to replace at least the solenoid on top. I suggest you replace the whole valve. Good luck
Posted on Nov 17, 2009
  • 3,600 Answers
First check to see if the filter is plugged, if it is replace the filter then if you still get no water look to see where the hose comes out from the lower or upper hinge then see if the hose is pinched in the hinge and squeeze the hose to see if you have any water in it and if it's hard or not. next look where the hose comes out by the ice machine and see if the hose is frozen there, if it is thaw the refrigerator and then insulate the line to keep it from happening. It may be the door switch that is your problem how ever and you will need to remove the ice and water despensor to look at it. if you want a diagram for the machine to take it apart and see where everything is located please post tothe e-mail you get from this site and I will send you the diagram.
MNTECH
  • 1543 Answers
SOURCE: GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Posted on Feb 08, 2009
SOURCE: My water dispenser in my GE refrigerator does not
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Posted on Oct 06, 2009
thedirkman
SOURCE: Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Posted on Apr 12, 2010
allbrands
  • 600 Answers
SOURCE: Water dispenser does not dispense water.
Hello, Thank You for using FixYa. I will be helping you today.The water tank is in the fresh food section remove the drawers and you will see it. Use a hair dryer and heat the tank and lines untill the water starts to dispense.
Thank You and please rate my answer if it was helpful..
Posted on Jun 15, 2011
  • 72 Answers
SOURCE: Electrolux 23 cu ft refrigerator (EW23CS65GS1)
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Posted on Oct 17, 2011
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
GE GSL25IGXB LS refrigerator. No water from front dispenser.Ice making works. Filter is good. Any suggestions?
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Jun 17, 2009 | Refrigerators
Feb 07, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Water despenser does not work
OK EVERYONE...
HERE IS YOUR SOLUTION FOR WATER AND ICE DISPENSERS ON GE UNITS NOT WORKING BECAUSE OF FROZEN LINES.
GET A HAIR DRYER...
USE THE HAIRDRYER TO WARM UP THE LINE THAT STARTS AT THE BOTTOM LEFT HAND SIDE OF THE FREEZER DOOR.
WARM UP EVERYTHING ALL THE WAY UP THE SIDE UP TO THE WATER DISPENSER.
WARM UP THE TUBE WHERE THE WATER COMES OUT.
(BE CAREFUL NOT TO PUSH THE WATER DISPENSER SWITCH...COMMON SENSE)
KEEP WARMING UP THE DOOR AND TESTING THE SWITCH UNTIL YOU GET WATER...
IT TOOK ME ABOUT 20 MINUTES...IT MAY TAKE LONGER DEPENDING ON HOW BAD THE LINE IS FROZEN.
I HOPE THIS HELPS...
Jul 04, 2008 | GE Refrigerators
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
278 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
