Question about HP LaserJet 2430 Printer
Tray can not be pulled out, little plastic lever is in top position although tray is inserted
  • metgrooves Nov 17, 2009
    used medium force, still nothing. tray moves out a little, but I would probably break something if I pulled harder. tried to move the lever up and down, too...nothing...cheers for any suggestions
    problem fixed, duplex unit shifted during transport and jammed tray 2 which is below the unit. needed to push unit back up slightly and voila, things worked!
    Problem Solver:
  • 7 Answers
The livers thread must be jammed try using a little force.
Posted on Nov 17, 2009
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Camry rear seat won't unlock
The plastic pull on the top of the seat may have been screwed down too much. If that happens, it will not allowing the lock mechanism to fully unlock. Unscrew the top plastic pull a little at a time and at the same time reach around and pull the lock leaver up until it is in the full unlock position. You should then be able to pull the plastic lever up normally and fold down the seat.
Nov 06, 2013 | 2001 Toyota Camry
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
Back seats won't fold down 97 toyota camry
Nov 08, 2011 | 1997 Toyota Camry
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
We need instructions for a Thermos pop up tent. we bought at a yardsale with no instructs.
Is it the tent with the plastic staves? If so, just put them together and insert the rounded end into the equivalent hole on the bottom of the tent. Sit the tent upright with the doors open. Reach into the top of the tent and push/pull the chrome lever at the top until it locks into position. Sometimes you have to wiggle it around a little to get it to lock. When it does lock, you will know it because the tent is rigid. This is a great tent. We have used one for over 40 years! When you want to disassemble it, just pull down on the chrome lever at the top of the tent and reverse the procedure.
Oct 12, 2009 | Sport & Outdoor - Others
Feeder tray not lifting
The paper tray is lifted by set of levers under the tray and the levers are operated by a motor, under the display panel. Check if the levers are in position. The motor movement is transferred to the lever by a plastic gear. Check if it is deformed. Normally motor does not fail.
S. Mohan, India
Aug 06, 2009 | Canon DR-9080C Path-Through Scanner
Key rotates but shift stuck in park. Windows and locks do not work, cannot start car.
Getting a Saturn L series with Automatic transaxle out of park to neutral is pretty easy. It is desribed in the owner's manua for my 2001 LW 6 cyl. Here is how it goes.
The plastic cover plate that indicates what Shifter position you have selected ( P R N D etc.) will pop loose with just a small screwdriver inserted at the top end (radio end) and pried gently. Once the plate is loose, locate a white plastic lever in the back section of the shifter hoiusing. Pull this white lever and the shifter will be freed to put in whatever position you desire.
Happy shifting!
Jul 27, 2008 | 2001 Saturn Lw 4dr Wagon
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
HP LaserJet 2430 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
