Question about EliteGroup GeForce 6100SM-M Motherboard
System shuts down. No blue screen etc. As if
Motherboard: Geforce6100SM-M V1
system shuts down. No blue screen etc. As if power has been removed. May take several attempts to get system running as it will seem to lose power mid way through power-up. yet other times will run for few hours. I've updated the bios to latest from your site. Changed RAM and added new graphics card.
Is this a known problem with a known fix or workaround.
  • 3 more comments
  • graham726 Nov 18, 2009
    Hi, thanks for the reply. All Capacitors look good, no bulging, discolouring etc. on any, no fluid discharge from bottoms and all appear to be stood straight.
    I think it may be something to do with the on/off switch. Generally when switching it on in the morning it may only run a few seconds. Each time the button is pressed it appears to boot a bit further until it will finally stay on for a reasonable period of time. This morning I pressed and held the button for several seconds and the system booted. I'll try this again when pc has been off for a while to confirm same results.
  • graham726 Nov 19, 2009
    Many thanks for the replies, but the problem is now very much on the back burner. Whilst trying to fix it I dropped a very large torch onto the flat screen monitor - which totally screwed it. So I've since gone and bought the missus another pc off ebay which is currently installed and working. So, finally got her smiling again at least. I'll look at the other pc as spares.
    Thanks again for the tips and advice.
  • joecoolvette
    joecoolvette May 11, 2010
    Sorry about your luck graham726. If you think it's the Power On switch there is a way to bypass the switch. The Soft Power On wire (Green), and any Ground wire, (All Black wires are Ground wires), have a temporary jumper wire placed between them. (Backside of 24-pin ATX Main, {motherboard}, Power Cable connector. Jumper wire is inserted deep, into the backside of the socket hole for each wire named. Use an insulated wire, 3/8ths inch insulation stripped back on each end. Jumper wire is used to make a momentary contact. There will be a spark. You may want to wear rubber gloves. (Example: Dishwashing gloves) Closer view of 24-pin ATX Main Power Cable connector,http://www.playtool.com/pages/psuconnect...
  • joecoolvette
    Updated the BIOS from what site? This is FixYa.com, not EliteGroup motherboards. There seems to be some confusion here. What BIOS version was it? What ram have you installed? What graphics card? Is this a new build? Are the standoffs installed correctly? (Spacers that hold motherboard above Support Plate) Do you want to know how to check your Power On switch to see if it's good, or bad? Concur with other expert. Could also be a power supply problem. Why? Those Ol' Capacitors I mentioned before. Do you have another known, good, power supply for a test? I await your answers.
  • joecoolvette
    Should like you to look at the Electrolytic Capacitors on the motherboard. Specifically the one's that surround the processor. See if any of them show visual signs of failure. Copy, and paste the link below into your address bar, and press the Enter key. Tells you, and shows you visual signs of capacitor failure. EliteGroup mobo's,(Motherboard's), are known for using cheap capacitors.http://www.capacitorlab.com/visible-fail...
  • 113 Answers
Sounds like either the fan on the cpu is giving trouble or the power supply itself. remove the cover and observe the fan to see if it is working properly also check the fan in the power supply. replace as necassary
Posted on Nov 19, 2009
    Sergeant:
    Champion:
  • 212 Answers
Could be a power supply problem. Have you tries to change it? Also set defaults in bios and see if it helps.
Posted on Nov 17, 2009
I have an MSI Wind U100 which was powered down without any drama but the next day when it switched on, the screen remained black and only the blue power light plus the Wifi and bluetooth indicators...
It is likely that the backlight went out on the screen. This model has an LED backlight and can be replaced. If you are mechanically inclined, you can purchase a new one on ebay or amazon and replace. If this is a motherboard problem, then it is likely not worth fixing. One way to tell is to see if the screen is completely black. To test, turn on the computer and go near a bright light source. if you can barely make out any image on the screen, then the LED backlight is bad. If the screen is as dark as it is when the computer is off, then it is likely the motherboard.
Apr 17, 2011 | Intel Motherboard
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ECS 6100SM-M hangs on POST
Check memory, remove or replace sticks of memory with just one piece in the slot closes to the CPU. Now try a power on and see if it boots. You have at lease one good stick of memory to boot.
May 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Power off issue for GX280
just run scandisk for your windows driver and check for any errors.
i once got this problem i just ran scandisk and some errors are found in the filesystem and they were removed
after that i have no prob shutting down my pc.
and if possible try to run a virus scan like avast or avg. etc.., this could take long if you have a monster harddrive and data.
hope this helps..
Apr 17, 2009 | Dell Computer Refurbished SYSTEM BOARD -...
Computer shuts down while loading OS
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
Mar 14, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
GeForce6100SM-M Intermitently Shutsdown
if there is a problem with one of the devices connections , or one of the devices chips are failing it will cause a shut down to protect the rest of the circutry.
try disconnecting all but cd/dvd drive to see if this happens , then only plug the sata or other ide including the power.
if a virus is in bios , resetting the clr bios and removing the battery on the motherboard can remove it
if the local area network is causing the shut down you would have data transfer problems or slow communications,
and there could also be a problem on the board
Oct 15, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Blue screen
unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
Computer restarts randomly with blue screen. How can I fix it?
Find the root of the problem by analysing the previous BSOD crashes. Its probably a hardware related issus (graphics driver or USB).
You need to enable the Memory Dump feature. This can be analysed when the system restarts to find out the root cause.
http://support.microsoft.com/kb/235496
Mar 06, 2008 | Microsoft Windows XP Professional
EliteGroup GeForce 6100SM-M Motherboard Logo
349 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
