Question about Advent Netbook
Hi my advent laptop says its wireless enabled but when i have tried to set it uo with my wireless router it says i have no connection i have been told by my internet provider to get intouch with advent but can't find a uk number for them! help pls xxx
  • 72 Answers
ADVENT
7070 - Fn+F2 (Basiclly a rebadged Medion RAM 2000)
7086/7096 - Button next to the power button
7100 /7104 - Fn+F2
7105 - (NFI)
7201 - Wireless key top Right and then Fn+F2
8117 - Small slide switch on the Front of Laptop
Posted on Nov 29, 2009
  • Advent Master
  • 4,806 Answers
You may have turn the wireless radio on first before you can connect to the internet.
Look down the sides of the laptop for a small slide switch and push it, an LED light should come on.
If you can't find a switch then hold down Fn and hit the F2 key.
Regards.
Posted on Nov 17, 2009
Hi. i'm trying to get my girlfriends notebook(advent 4213) connected to the net. i am using my own wireless net but when i click on the net it comes up saying this page cannot be displayed. do i h
If the Advent notebook normally connects to the internet without problem on her network, then you need to check the following:
1. That she does not have any proxy connection setting in her web browser that you do not use on your own network.
2. Check that her wireless adapter is configured to Obtain an IP address automatically and also Obtain DNS server address automatically.
3. Check the status of the wireless adapter connection and ensure that the Advent notebook has been given a valid IP address, i.e. if your are connecting to a wireless router on your network, you should see an address something like 192.168.x.x where the x.x depend on how your router is setup. If you see a 168.x.x.x address then the notebook is not getting a valid, routable IP address and you should try to do a Repair of the network adapter connection. Repair may also be shown as Diagnose and repair depending on which version of Windows is used.
Jan 07, 2012 | Computers & Internet
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
Have an advent..use 3 dongle to connect to internet...in an area where there is no signal..this house has a router for wireless but i cannot get on..help..
Try to power cycle the modem as well as the router , disconnect all the filter and then turn off the modem and turn it back on make sure all lights are in green then try to connect internet cable first check if you have internet connection using cable then try to set-up your wireless connection again .
ERNZ
Feb 04, 2010 | Advent 4211c Notebook
How do you connect Advent N1996 notebook to the
Need a little more info...But to get you started:
If you are only using a modem, insert a ethernet cable into the modem and your netbook. You should get access to the internet right away.
If you are trying to connect wirelessly through a router, it really depends on what type of router that you have and the type of security that you have enabled. In most cases, all you should have to do is enter in a passcode or passkey to gain access.
You might also want to make sure that your wireless card is turned on. You can usually find a little switch with an picture of an antenna with half circles coming off of it.
Jan 08, 2010 | Advent Netbook
2wire312
You may want to double-check if the wireless adapter on your laptop is enabled. If it is enabled, try to view the available wireless networks on your wireless connection and select the name of your wireless network. You may also want to check your wireless router if there is a wireless security enabled. It is important that you know the wireless settings on your wireless router to make sure that the wireless adapater settings on your laptop match the settings on the wireless router.
Jul 02, 2009 | 2wire HomePortal® 1800HW Router...
Cant connect wireless internet connection
pls configure first WAN setting WI FI AREA NETWORK,IP address connection from the router wi fi,subnet, and protocol.
May 10, 2009 | Recoton Advent Advent Q2035A 20" TV
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Nov 14, 2008 | Belkin Computers & Internet
Internet wireless connectivity
This is a common and annoying problem. Your router is running and connected, but they are either not using the same encryption keys or else you have some other setting incorrect (encryption type is a common one).
Turn off the laptop's wireless connection and enable its cable (wired) connection. Connect the laptop to the back of the router physically with a network cable. In a browser type 192.168.1.1 (or other similar number - check your router's quick start guide). Log into the router and go to the WIRELESS SETTINGS. Write down everything you see (channel, station ID, encryption type and key, and whether MAC ADDRESS LOCKING is on (if it is turn it off for now)). Take these settings, reverse the process on your laptop and try to connect wirelessly with the new settings. They have to be exactly the same
If it all works, you need to go back into the router and enable MAC ADDRESS LOCKING after giving it your laptop's MAC ADDRESS, enable the highest standard encryption both the router and the laptop support, and turn off station ID broadcasting if possible.
If you still cannot connect wirelessly, connect again through the wire connection, and turn off encryption, turn off MAC ADDRESS LOCKING, and try again.
Good luck...
Nov 16, 2007 | Belkin (F5D6230-3) Wireless Router
Advent Netbook Logo
955 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
