Question about Samsung SyncMaster 203B LCD Monitor
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards Ertan Cetin
  • Samsung Master
  • 1,684 Answers
A blinking power light on the Samsung 225BW usually indicates a failure in the power supply board. There are parts called capacitors that start to fail and this causes the power supply to keep restarting trying to stabilize the output voltages. If you can do a little soldering then you should be able to repair the unit yourself. Here is a link to a repair guide for the 225BW with pictures and a video showing how to dis-assemble the unit and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
There is also a parts list of the capacitors you need to get for the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Dec 27, 2011
  • 115 Answers
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Posted on Nov 17, 2009
Samsung Syncmaster 225BW startup problem
reinstall the driver. what was the last update that you applied in general. revert back to LKGC last known good configuration.
Mar 07, 2014 | Samsung SyncMaster 225BW 22-Inch LCD...
My SyncMaster 225BW 22 inch does unpredictable displays when my PC is first started up, or awakes from sleep mode. (display is shifted to the right, or brightness is stuck on very low, etc.). Before, I...
The brightness issues with this model are usually caused by a power supply that is starting to fail. There are parts called capacitors that start to fail, when this happens the power supply can not get to the correct voltage outputs that it needs to properly run the back light bulbs. This type of problem causes either the dim display that you have or a wavy display until the unit can stabilize the output voltage. It is repairable if you can do a little soldering. You will need to replace the 5 capacitors on the power supply board. Here is a link to a repair guide for that unit that shows what needs to be replaced.
This is an easy fix, about 15 minutes once you have the parts.
Feb 04, 2011 | Samsung 225BW LCD Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Monitor is ghosting, white trails.
You might want to try detaching the monitor and trying it on another computer unit to see if the problem still exists.  If it only occurs on your unit, then try updating the drivers on your system and see if that solves it.
Jun 30, 2010 | Samsung 225BW Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Samsung SyncMaster 203B LCD Monitor Logo
563 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
