Question about Whirlpool AWM6100 Front Load Washer
Whirlpool washer problem
When washing cycle is finished the spun washing is hot. The machine is plumbed to both hot and cold taps but the temperature of damp washiong indicates it is being rinsed in hot water. How do I fix this?
Also is there a way to propgram only a cold water wash and rinse with the AWM 6100
  • Anonymous May 12, 2008
    I would like to do a cold wash cycle? Is this possible? It is plumbed to both the hot and cold taps. Please advise asap???
If you read the manual it says that the 30 degree wash doesn't actually draw anything from the hot water tap. This is the cycle I use and I don't turn my hot tap on unless I want to clean my machine once every 6 months.
Posted on Jun 28, 2008
What happens if you just turn off the hot tap?
Posted on May 15, 2008
  • 121 Answers
It sounds like you cold inlet need replaced its a easy job
Posted on Mar 03, 2008
Machine will wash on hot only will not on cold or will not fill with cold at all
This is an indication that the solenoid on the cold water valve is bad. Or the cold water valve is plugged. If you can get to the valves, use a meter to check the solenoid OR the power to the solenoid. That will tell you if it is bad. If you dont have a meter, switch the wires from one solenoid to the other and see if it fills
Feb 01, 2013 | Whirlpool Clothes Washer Heavy Duty...
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
I have a wtw5800swo washer. The washer will complete the wash cycle, but then shuts off and will not enter the rinse cycle.
Be sure to guarantee that BOTH hot and cold taps are turned on. Commonly, the hoses get reversed, and dad turns off the hot water (due to high bills) and the hot is connected to the cold tap, which is used for rinse, so the machine will wait forever for the water...
Apr 07, 2011 | Whirlpool WTW5850S Top Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
Jan 11, 2011 | Whirlpool WFW9400S
Our temperature control isn't working. If we put
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Apr 01, 2009 | GE WBVH6240F Front Load Washer
Whirlpool Duet washing machine - no cold water comes in when I put it on cold cycle
Check the tap is turned on
if not fix
turn off taps, check the lint screen inside the hose end (tap connector end) is not blocked
if not fix
check cable connections on cold water solenoid valve inside rear of case
if not fix
replace cold water solenoid.
cold water solenoid valve fails more often than hot, is used on every cycle so bnurns out first.
unplug washer and turn off water before checking cables or replacing solenoid.
solenoid is cheap, common to many washers local parts guy will have one that fits even if it is labelled ge frigidaire kenmore
Sep 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
226 people viewed this question
Dan Webster
Dan Webster
Sal De
