Question about Tally MT661 Printer
Error message bad esc seq - Tally MT661 Printer
    Novelist:
  • 169 Answers
The Bad Esc error you are seeing indicates the pritner is reciving data from the host computer system that it does not recognise, the most likely cause for this error are;
  1. You are not using the correct pritner driver to print to the pritner
  2. The Emulation setting on the pritner is not correct, you can check this via the printers menu - I would guess the pritner has defaulted to MT660 emulation and it needs to be set to Epson or IBM emulation
Posted on Nov 20, 2009
  • william Fleming Mar 31, 2012
    put it in dump mod that way u will se the hex character printed
2 Suggested Answers
  • 169 Answers
SOURCE: Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
Posted on Sep 18, 2009
I have a Singer Futura Quartet SEQS-6700 sewing machine. Keep getting error code 16, but there is no explanation in the product manual. Can you help?
Generally the error message is due to "some" electrical overload. It settles itself most times by turning off the sewing machine for a few seconds to allow complete shut-down and then turning it back on. It the error message returns, it is best to visit your qualified local technician.
Nov 07, 2014 | Sewing Machines
Hello, my problem is that i can t startup my laptop Lenovo R61i i think that problem is in BIOS. Can u help me please? Thank u.
when you first try to turn it on you need to press the esc. button or f1 to enter the setup menu,check your bootup sequence,make sure that your hard drive is being accessed first in the bootup seq.hopefully this will let you startup!
Dec 24, 2012 | Computers & Internet
Does anybody know how to flash the firmware of an avaya 5610sw IP from the VPN to the regular in office
1) Edit your existing 46vpnupgrade.scr file as follows. Don't forget the line at the very bottom of this document!
2) Next set your phone's GROUP back to 0 by pressing the MUTE button (just press it don't hold it down) then enter GROUP on the keypad (47687) and press #.
3) Reboot your phone and the non VPN firmware should be re-installed on the phone.
# Release Date: August 26 , 2007
# 46XX Software Upgrade Script for VPN Capable H.323 IP Telephone
# This file upgrades the following telephones to the
# indicated releases:
# 4620, 4610, 4621, 5610 VPN Build 252
# 5620, 5621 VPN Build 252
IF $GROUP SEQ 0 GOTO NOVPN
IF $MODEL4 SEQ 4610 goto DEFVPN4610
IF $MODEL SEQ 4620D01B goto DEFVPN4620
IF $MODEL SEQ 4621D01A goto DEFVPN4620
IF $MODEL4 SEQ 5610 goto DEFVPN5610
IF $MODEL4 SEQ 5620 goto DEFVPN5620
IF $MODEL4 SEQ 5621 goto DEFVPN5620
goto END
# DEFVPN5610
SET APPNAME i10aVPN23252.bin
goto END
# DEFVPN5620
SET APPNAME i20aVPN23252.bin
goto END
# DEFVPN4610
SET APPNAME a10bVPN23252.bin
goto END
# DEFVPN4620
SET APPNAME a20bVPN23252.bin
goto END
# DEFVPN4625
SET APPNAME a25VPN25252.bin
goto END
# END
GET 46vpnsetting.txt
# NO46xx
# NOVPN
GET 46xxupgrade.scr
Oct 14, 2010 | Avaya 5610 IP Phone
L can't boot xp from my cd rom in nec versa 680
need to change the boot seq in BIOS....
u need to press one of the foll...
DEL, F1, Esc, key etc as the case may be...immediatly after switching on the PC....
once u r in BIOS screen look for "Boot Seq" in one of the BIOS setup screens....
change the boot seq to CD ROM as 1st boot device...and HDD to 2nd boot device...
press F10 or choose BIOS "save and exit " option....
insert the XP cd...switch off and switch on...it should now boot from CD....
all the best....pls revert back...pls give a rating and feedback for this advice....thanks
Sep 27, 2010 | NEC Versa FX Notebook
ON REBOOT, I GET AN ERROR MESSAGE "Cannot find disk.Press any key to reboot" HELP, PLEASE
ur boot seq in BIOS is not in the correct order
if u know how to enter BIOS then make the seq to boot in the foll order
1 boot - CD ROM drive
2 boot - Floppy drive
3 boot - HDD0 or HDD1 or HDD2 etc(in that order)
press save and exit BIOS and reboot
Jan 18, 2010 | Acronis Migrate Easy 7.0 (AME7)
Bad ESC Seq
Press ENTER
May 22, 2009 | Tally MT645 Printer
DATA ERROR 40!
Hello
Here is what the manual says. It might help you decide what to do next.
Mar 16, 2009 | Casio Algebra FX 2.0 Calculator
359 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
