Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F93 error. Oven door is stuck, won't open. Display is flashing door locked and continues beeping. This happened once before and a repairman had me press a few buttons and it reset and fixed the problem, but I can't remember which buttons. Please help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock time exceeded." Actually it's trying to lock the door but is not aware of the time to stop. Please check the micro switch and lock’s motor. Replace whichever has gone bad. To reset it turn it off for more than 10 minutes and then turn it on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 17, 2009
  • Steve Leahy Oct 20, 2015
    I just replaced the motor assembly and the motor WAS previously not working, but now cycles, but does not recognize the lock in the locked position. What is the supposed output voltage showing locked??
I have replaced the lock motor and it is moving to lock but still getting the F93 error code, any idea
Hey Steve, thank you for your post! Typically the error code"F93" reflects that there is a problem within the door mechanism, such as, the main board, lock motor micro switch and/or the light switch. If the error continues, I would seek assistance from a professional for proper diagnosis and repair to be completed on your oven. I hope this is helpful. -JK
Oct 20, 2015 | Frigidaire 30 in. Electric Gallery Pro...
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Over door locked
Error code F93 means the lock motor assembly spent too much time to lock. Someone needs to read the continuity of the lock switches and the door switch and apply 120 volts ac to the lock motor to see if it will run. If the oven is less than 1 year old you should schedule service and let a technician diagnose and repair the problem. If you want to repair the oven yourself make the checks with a volt/ohm meter and send another email if you need more advice.
Dec 17, 2008 | Frigidaire FGB24S5A Gas Single Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F2 error
what is solution
Dec 08, 2007 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,598 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
