Question about Nokia 7610
I want to repair the antenna of my 7610 what would i do...
I have 7610 phone security prob how to repair this
whats the problem in your nokia 7610? have you forgot your security code and struggling? just try to reset your mobile with master reset code to get rid of your problem if you have forgot your security and if its any other problem you can contact your service center..for master reset codes try unlocking4free and get codes by entering your mobile's imei number..
Aug 04, 2011 | Nokia 7610
My nokia 7610 light on the keypad no light on the screen
how to use a jumper? my nokia 7610 has a keypad problem, it had been repaired once, but it came back.. then later after i had just checked it without doing anything on it, it happened that the light went low and there's no more display on the screen..
kindly help me :( if there is a solution for this before i'll bring it to a cellphone repair shop.. so i can have lesser expenses..
thanks in advance..
Nov 04, 2010 | Nokia 7610
Nokia 7610 charging
First insure that is your charger ok? you can try it by using other charger. if your charger is ok then check your charging connector.but if the section is ok in your mobile charger section which name "k" is bad. then you need to change that. thanks
Feb 25, 2010 | Nokia 7610
The antenna of my nokia 7610 are not working... what would i do to troubleshoot this prob,
Its called P.I. You can replace it from any mobile repair shop.
Nov 17, 2009 | Nokia 7610
My signal are not working? i want to troubleshoot this problem.... but i have no idea.... can you help m for this
Antenna will cause this problem.So You can give youe phone in any authorised service center and get it serviced...This problem will get over....Hope you will succeed...Thank you...
My nokia 7610 phone has been dropped in water
You should detached quickly its battery first. It is to prevent further damage to your unit. And dont try to power it on. Then bring your unit to a cellphone shop to have it dry and clean it for you, they will sometime automatically charge for water damage repair.
For minor damage only battery pack will get damaged. Luckily only cleaning and drying will get it running.
Apr 17, 2009 | Nokia 7610
SIM CARD NOT VALID
It software problem tray to do init sim lock with Tornado Box repair.
Mar 22, 2009 | Nokia 7610
There is no network coverage in my mobile (nokia 7610). If i go for manual search for operator selection it results in "no operator found". But if i put the same SIM card in any other mobile then there is...
If searcing manually say no operator found,it means any problem with receifer in your phone,for 2-4 scnd (than operator not found)check antenna and its connector.for 5-7 scnd check switch antenna. for 8-10 check RF IC. for 10 scnd up Check UEM(power IC) and CPU.But for safely do a software repair with a good PM.
Jan 27, 2009 | Nokia 7610
Nokia 7610 switches off automatically
nokia 7610,
can be rectified..but it will just cost u much for repairs..once u let that to be repaired,another problem will *** in..
u should look for a new one..
Apr 07, 2008 | Nokia 7610
Repair
my mobil nokia 7610 some time tower problem plz replayl solution
Sep 17, 2007 | Nokia 7610
Nokia 7610 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
