Question about Cell Phones
High pithed whistle when tv is on through S/sound
I have a new Samsung HTX720GT cinema system on to my new Samsung 40'' 8000 series tv. trying to put TV sound through the system and there is a whistle in the back ground, how do I get rid of it please?
  • simon624 Nov 17, 2009
    Sorry may have misled you, the tv is this year's LED tv and the Samsung s/sound 2:1 is supposed to be compatable. The system is connected with HDML cable for the DVD and also "digital/ audio (optical) cable to take the audio from the tv ot the s/sound. When using a DVD it is perfect but when watching tv channels there is a high pitched whistle coming from the speakers.
  • Cell Phones Master
  • 2,113 Answers
If this is an audio question then let's assume that there are differing grounds between each unit.  There are devices on the Internet that show that they can remove any background sounds between two devices with differing grounds.   http://www.beststuff.com/audiovideo/xitel-s-new-ground-loop-isolator-stops-speaker-hum.html
Could you have plugged in an analogue stereo into a digital output on your tv?
If it is a component inside the tv then this may answer the question.  I found a high pitched ring in a tv i owned once.  It was a fixed coil inside that wasn't factory glued tight enough to not vibrate using it's magnetic field.  it looks like a ferrite rod with magnet wire wrapped around it but just one layer and only about an inch high.  It is probably similar on your tv.
Posted on Nov 17, 2009
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
Whistling sound
This tv whistling sound are causes by a high voltage currents flow from it is tv power supply board it self not functions properly anymore.That the board where the power a/c cord plug into it.Those high voltages tranformers have gaps in it solders joints and now it not letting high voltages currents flow smoothly anymore,that where the whistling sound came from.Tries take the tv aparts,tries to put some kind harden or supper glues to all those high voltages tranformers,might help or soften the whistling sound alot.If that did not help all or alot.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 28, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
How do i get the sound from my Philips TV into my samsung 2.1 home cinema system?
To get sound from any TV (including Philips) to an amplifier or a home cinema system, the TV should have a LINE OUT RCA pair. Thereafter, it is a simple case of connecting said Line OUt to one of the INPUTs of the cinema system.
Often (but not all), Cinema Systems have their own TV tuner and would provide a video out that could be connected to the Video IN of the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Samsung Televison & Video
Advice on the best way to connect
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
Jun 29, 2008 | Samsung Audio Players & Recorders
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Jun 15, 2008 | Audio Players & Recorders
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Cell Phones Logo
117 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
