Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Hi! I have the same problem as matthew_wils (sep 26, 2009) "Samsung F480. Using Samsung Media Explorer to transfer items. Able to transfer music and photos but would like to transfer SMS to computer. When connected, it says loading SMS, but then does nothing and just disconnects. Any help please." I really want to save my sms', and I can't find a solution, please help!
Samsung media studio doesn't recognize my mp3 player
Why doesn't my computer recognize my MP3 player, and other ...
ask.metafilter.com/.../Why-doesnt-my-computer-recognize-my-MP3-pla...
Jun 17, 2008 - Problem 2: when the MP3 player is connected to the laptop, theSamsung Media Studio program recognizes it, but not completely. As in, I can ...
Computer won't recognize Samsung YP-k3 - Forums - CNET
www.cnet.com > Forums > Headphones & Mp3 Players
CNETOct 10, 2007 - I tried to update the drivers for it in my PC, but it just says "hardware could ... Using Samsung's K3 MP3 Player with Windows 2000 ... To use Samsung's Media Studio with the player in W2000, run ... The link doesn't work. Problem with Samsung YP-T10
Jun 11, 2015
Samsung YP-T9J no longer detected by computer
Sep 1, 2007
Samsung YP-K3 won't turn on.
May 31, 2007
Samsung YP-T9 Play transferred music file
Dec 19, 2006
More results from www.cnet.com
Samsung Media Studio - Informer Technologies, Inc.
samsung-media-studio.software.informer.com/
Dec 21, 2015 | Samsung YP-T10 Digital Media Player
How can i get itunes to download on my phillips gogear 4gb?
Transfer music via Windows Media Player 10:
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
How to download music from computer to my philips gogear audio player
  1. Hook up your GoGear to the PC via the supplied USB cable.
  2. Plug your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Media Player 10.
    Note: Once the device is connected to the computer, all audio or radio playback will stop.
  5. Click "OK" to close the windows.
  6. Click the "Sync" tab.
  7. In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
  8. Click the check boxes next to any files you want to copy.
  9. In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
  10. Click the "Start Sync" button.
  11. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  12. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  13. Once the transfer is completed, close Windows Media Player.
  14. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Note! You cannot transfer pictures via Windows Explorer, for pictures you need to sync them using Windows Media Player.
  1. Connect your GoGear to the PC via the supplied USB cable.
  2. Connect your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Explorer.
  4. Drag and drop your music files into the Media/Music folder of your GoGear.
  5. Once your music has been transferred to your GoGear disconnect it from your computer and you are ready to listen to your music.
if this it was helpful rate my solution and vote me thanks
Jan 06, 2010 | Philips GoGear HDD1830 MP3 Player
Samsung Tocco Lite - Unable to create default folder
Instead of using 'PC studio' option while connecting, use 'media player' option for transferring the files. Check this option. If this does not work, try creating the default directory yourself manually using the phone and then try transferring the files.
Sep 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Suddenly my player can't transfer music files(mp3) (using windows media player). a message pops out saying that an unknown error occured/ player disconnected. im not even touching it while it's connected!...
Hi ! it´s a better idea to transfer you music using the explorer make a folder with your favorite music and then copy to the device if your device appears as a mass storage device.... ;)
Hope it helped
Jun 24, 2009 | Audio Players & Recorders
Downloading music to my samsung tocco
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer much easier...
Apr 13, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung tocca f480
If you install the samsung pc studio and usb driver you can connect you phone to your pc. Then using phone explorer it is possible to copy music into the phone's memory.
A slight annoyance is that it seems to lose the artist, album details etc from m4a files. I got round this by creating folders for artists on my phone and copying tracks into said folders.
Apr 02, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How to transfer music from pc to samsung tocco?
Put your tocco in media device mode when you connect it to the PC and just use windows media player to sync to the device, its a doddle. Forget the Samsung software, its rubbish!
Feb 21, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung tocco problems
i want to transfer my photos from samsung tocco to my computer .How to do that?
Feb 11, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
166 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
