Question about Dishwashers
Kenmore model 110 dryer does not get hot. did not trip breaker
  • 5,911 Answers
If the dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
The heating circuitry is usually located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please post back with your complete model number (usually located on a nameplate around the door opening) so that I may be able to provide you with better assistance. "110" is the manufacturer code that identifies this dryer as made by Whirlpool. I hope you find this helpful.
Posted on Nov 17, 2009
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
I have a frigidaire Dryer (4 years) model #AGQ7000ES1. The machine turns on but it won't heat. I ran all the diagnostic tests that the manual outlines and the test came up OK. No malfunctions. All air...
There are two 110 volt supplies to an electic dryer. One supply will supply all operations of the dryer save half of the heater ckt. The heater requires both 110 supplys for heater operation. Check if one of your two 110 dryer breakers in your house is "tripped" to off. If it works when you trip it back on good, if it only works temporarily then trips again, suspect a bad heater element drawing too many amps. Another possiblity is a weak breaker in the house breaker box, but usually if you get a reoccuring breaker trip its the dryer heater element pulling too many amps. Hope this helps.
Apr 27, 2011 | Frigidaire Dryers
I have a Kenmore 90 series electric dryer that will not heat. Model is 110.62922100. I have the schematic and have checked all the thermostats, thermal cutoffs,timer contacts,the motor rotational switch,...
Check your breaker box. If one side trips it will run but will not heat. Common problem. Try checking L1 to N, and L2 to N, you should have 110 and 110 if you dont than it,s your breaker. I would just check your breakers. Make sure you give me a thumbs up if I am right.
Aug 21, 2010 | Kenmore Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Kenmore 400 series dryer won't start
If you checked the voltage at the terminal block on the back of the dryer while it was plugged in, you should have gotten the following readings:
RED to BLACK = 220-240VAC
RED to NEUTRAL (White) = 110-120VAC
BLACK to NEUTRAL (White) = 110-120VAC
NOTE: If the wires are not color coded at the terminal block, the OUTER two wires (LEFT and RIGHT) are the HOT leads and the center conductor is the NEUTRAL.
If you got anything other than these readings, you may have a bad power cord or a service breaker tripped. Some homes use two separate breakers to make up the 220 service instead of one single 220 breaker. If one breaker is tripped, the dryer may or may not start, depending on which leg it is. Can you please confirm your readings?
You need to confirm you have the proper input voltage before assuming you have any bad components.
Sep 05, 2009 | Kenmore Dryers
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
I have A kenmore Elite Model #110.65942400 Ser MR2103237.
before you take it apart make sure you have not lost 1 phase of the 220 volt line into dryer , dryers will run and appear fine on 110 volts be will not heat check fuse or breaker and re-set breaker even if it does not appear tripped , if fuse in line turn off power and remove fuses and check with an ohm meter , then if you have a volt meter check for 220 volts @ socket of dryer , then we will talk dis-assembly
Dec 01, 2008 | Kenmore 659 Electric Dryer
Dryer turning but not hot
First check your electrical panel and make sure the breaker is not tripped. If breaker is not tripped you could have a blown fuse inside of the dryer or the element could be bad.
Nov 02, 2007 | Dryers
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
