Question about Lexmark Office Equipment & Supplies
My x6575 suddenly has two black stripes running down the one side of the paper. what's going on?
  • 643 Answers
Hello and welcome to Fixya.
This could be due to a few factors. there could be ink on the rollers or fusers, the Cartridges could be starting to run low...
Here is a test you can do
Load plain paper.
( from the printers control panel)
Press Settings.
Press left or right until Maintenance appears.
Press check
Press left or right until Clean Cartridges appears.
Press check
This should start the nozzle cleaning process,
Now try to print a normal document to see if the lines are gone..
If they are still there, try the nozzle cleaning process again.
If that doesnt help, please go here to view your manual,
http://www.lexmark.com/publications/pdfs/2007/6500/v4897402_en.pdf
In the manual it has a selection for "wiping the print cartridge nozzles and contacts"
Scroll to that section and it will show some images on how to do this step.
Thank you for using fixya, and if you have any futher question please feel free to ask!
Posted on Nov 17, 2009
Black line on left side of paper
I forget the terminology but I believe there's either dirt or a sheet of paper on an internal roller.
You might try here for HP help.
Aug 12, 2012 | HP LaserJet 1300 Printer
Hi, my x6575 prints with vertical perforated lines down the center, how do I get it off?
It could be because of the paper type you are using. Try to use a different type of paper and check if "perforated lines" still appear. If problem happens to all types of paper that you've tried, please don't hesitate to contact Lexmark technical support for additional assistance.
May 14, 2011 | Lexmark X6575 All-In-One InkJet Printer
BLACK STRIP ON THE LEFT SIDE ON MY PAPER??? I HAVE A HP LASERJET 1022NW....WE HAVE CLEANED AND BLEW OUT THE PRINTER....STILL NO IMPROVEMENT....WHAT TO DO NEXT....
Run the 1/2 print test.
Put paper in the manual feed tray. Print a few pages of anything. As the paper gets about 3/4 of the way into the printer, open the cartridge door. Pull out the cartridge and look down at the paper. If it has the black stripe on the left side, replace the toner. In fact at this point, pick up the toner cartridge and gently swing the shutter open and look at the drum. You should be able to see a black stripe on it.
By the way, the toner hasn't been fused to the paper at this point. It will rub off on hands and clothes.
If the 1/2 test shows no stripe on the paper...replace the fuser.
Dec 01, 2010 | HP Office Equipment & Supplies
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Black vertical Stripe
Move the blue slider on the drum cartridge side to side 10 times.
Jan 30, 2009 | Brother IntelliFAX 5750e Laser Fax
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
