Question about Euro-Pro HEPA Shark EP238 Bagged Canister Vacuum
Euro-Pro head cranky
It's a Euro-Pro EP238 canister vac. The air-powered brushroll in the head sometimes doesn't spin.
I need helping fixing it for finding a replacement, even a compatible model.
  • justmeroofie Feb 21, 2008
    I need to replace brush system, Where do I find parts?
    President:
  • 1,673 Answers
The air driven head is probably bond up and needs to be cleaned. Alot of the air driven ones have a belt that may be broken or stretched.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
There is no suction in my vaccumm
CHECK LIST
1. Full or clogged dust bag.
2. Dirty air input filter.
3. Wrong pile height setting.
4. Open suction control.
5. Hole in hose.
6. Canister hood open
this link is for the manual
http://www.sharkclean.com/manual/EP238_0602A_1yr_warr.pdf
Sep 26, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Need bags for the euro pro x ep 238
Needed bags for this vacuum and FINALLY found them at http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005. Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum..
Aug 06, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
How do I fix the shark vac and steam . the steam is not working
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 10, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Lubrication for powerhead motor
the power head motor dose need service first thing you should do is take the top cover off by removing the screws on the bottom of power head then remove brushtroll clean brushroll and the end bearings make sure they spin freely squirt some lube (wd40n or tri flow) on the end cap bearings . Then clean motor by blowing it out with compressed air lube bearings with either wd40 or tri flow that should free up the motor and brushroll
May 26, 2009 | Vacuums
My hose cracked on my ep238
I've had the hose brake on this vac at both top and bottom several times. You can pinch the ears that hold the hose assembly to the wand and vac connection and get at the piece that the hose screws into. Remove the old piece, cut the hose cleanly and screw back in, then snap back together. They don't seem to have this hose anymore and since the vac also has problems with its cord assembly I'd say your best bet is a new vac once the hose can't be fixed anymore.
Apr 13, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Euro-Pro HEPA Shark EP238 Bagged Canister Vacuum Logo
125 people viewed this question
Top Euro-Pro Vacuums Experts
Mark Bowens
Mark Bowens
Roxanne Jones
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
