Question about Keurig Elite B40 Coffee Maker
Water container cracked need replacement - Keurig Elite B40 Coffee Maker
    Champion:
  • 213 Answers
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Water is leaking out of my coolant container.car is overheating with less than 2 mins of driving
Need to seal the leak in the coolant container with epoxy or by replacing the coolant container.
Fill coolant system with 50/50 solution up to 2 gallons may be required to stop the overheating.
Don't drive an overheated engine.
Aug 11, 2010 | 1993 Saturn SL1
The water container has cracked and does not hold water. Where can I buy a water container replacement?
Follow this tip to see if you can find the part you need... dehumidifier parts are not all that common and are not readily available...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
How to find Air Conditioning, Heating and Furnace parts online
http://www.fixya.com/support/r4016017-find_air_conditioning_heating_furnace
heatman101
May 06, 2010 | Fedders R6DH45X Dehumidifier
WINDOW WASHER CONTAINER CRACKED & LEAKING - VOLVO S70
not that hard. you need to remove the wheel arch and its right in front of you
Dec 02, 2009 | 1998 Volvo S70
No quick fix for this one. A new container is required.
Oct 08, 2009 | Keurig B50 Coffee Maker
Leak in the left door (water dispenser)
ck container to rule out simple leak ck for cracks in container make sure lines are secure and free of breaks also part can be ordered. first ck all basics lines and conections in compartment
Aug 18, 2009 | LG LRFD25850 Stainless Steel French Door...
Water suddenly started pouring out of the location where the water filter is connected. We checked and it is properly seated and screwed in. We had to turn the water supply off. This is a GE Cafe side by...
We had this happen several times to us, too. I finally figured out that anything that pushed against the filter would cause the collar to crack. It needed to be changed. My solution was to slip a simple plastic container around the base of the filter while I was replacing it and presto! The container does not allow anything to push up against the filter. Problem solved.
Aug 11, 2009 | General Electric Cafe CSCP5UGXSS Side by...
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
Keurig Elite B40 Coffee Maker Logo
214 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
