Question about APC - UPS - Matix/Symmetra Enterprise UPS Symmetra 12KVA Expandable to 16kVA N+1 Master Frame (SY12KEX) UPS System
Matrix 3000 "bottom fan fail" need a replacement fan. APC said they don't have in stock and is discontinued.
The APC Matrix-UPS 3000 Isolation Unit IU bottom fan APC part number appears to be 490-0006-A. There are three OEM parts that APC appears to have used:
NMB Technologies 4715KL-05W-B30-P00
Japan Servo CNDC24B7-34
Sunon KDE2412PMB1-6A
But any fan that has the following specs should work:
119mm x 119mm x 38mm, plastic (black) 94V-0, ball bearing, 2-wire, 24 VDC (9.0V min, 10V to 27.6V), 2800 RPM, 80 CFM min, 41 dbA max
Posted on May 24, 2013
  • 37 Answers
SOURCE: APC Matrix 5000 Electronics unit
where are u from ? here my email brokenbutte@yahoo.com.sg
Posted on Jun 05, 2009
  • 541 Answers
SOURCE: Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Posted on Dec 27, 2009
  • 28 Answers
SOURCE: Getting alarm after genuine APC battery replacement
I've seen where the software can hold on to past readings and give erroneous alarms. Try uninstalling the software and reinstalling if all else fails.
As a last resort, try disassembling the battery pack and checking the voltage of each battery. Each should read 13 vDC (+/- .5v). There are several batteries in this pack so one bad battery can pull down the whole string.
Posted on Feb 12, 2010
KingOfKYA
  • 94 Answers
SOURCE: My APC Matrix 3000 sitches
1This is generally caused by your devices. Drawing too much current over the 30amps the device is rated for. Or you have a failed or failing inverter (12v to 120vAC converter). Sounds like you issue if it switches off every few seconds.
2 I would suggest removing a few devices to see if it resolves the issues if it dosen't look for other devices on the same curcit witch maybe spiking the voltage on the line. Laser printers, and coppers should be the first devices looked at. As they cause a huge electromagnetic spike when they turn on.
Also note drawing over 30amps may not flip the breaker on the wall outlet. Simple because some ups are always running off there batteries and simply charge them as you use it.
Posted on Jul 04, 2011
epettingill
  • 175 Answers
SOURCE: how to reset date after battery replacement of apc
To reset Bad Battery light on the Smart cells:
Old smart cells have a removable cover on the back to allow the "socketed chip" to be replaced.
Newer ones have SW1 pads on their circuit board.
Newer Smart Cell or XR Cabinet
1. Unplug the phone cord from the smart cell and wait a minute for the controller to go to sleep
(Bad battery indicator goes dead)
2. Then push the reset Button while plugging the phone cord back in.
3. If it is blinking after plugging back in, disconnect and wait till dead and try again.
4. If the batteries are good you should not get a light at all. Retry the reset at least 2 more times before
blaming the card.
Older Smart Cell
2. Short pins 17 and 28 (Right Side, Top and Third from the Bottom), while plugging the phone cord back
in.
When it works the red LED will be blinking indicating a bad Battery, it should stop blinking when the phone cord is plugged back in.
Note: Smart Cells are functional when LED is blinking
Posted on Nov 03, 2011
I need a replacement receiver for Hunter Palermo Ceiling Fan, part number: ********** Remote Transmitter. This part is discontinued, need replacement.
Unclear whether you need replacement receiver or transmitter but "big box" home improvers have been known to stock them.
Nov 16, 2016 | Hunter Dryers
Ruel is the name I am on the island of Jamaica. How or where can i get acess to repair manual (APC 1400/ smart rack mount 120 v 2000/3000 Rm u3 models
For starters, have you tried APC website? Plenty of manuals there man. Check it: http://www.apc.com/search-apc/ww/en/relevance/10_1/Product%20Information;;7B0CB5EA-CEC6-4E31-B9A6-51E4DCFADB54/all?search_text=APC%201400%20pro.%20Smart%20Rack%20mount%20120%20v.%202000%2F3000%20MR%20U3&search_type=new&filters=
Oct 12, 2014 | APC Computers & Internet
How to reset date after replacing batteries for apc matrix 3000(mx3000pe)ups
First you need to get a APC serial cable from APC. Next connect it to a com port on your computer and the back of the APC. On your computer start Hyperterminal. Enter a file name. Anything will do. Slect your com port. Set the following setting to 2400 data bits and none for flow control. Leave the other setting as is. Hit enter twice and enter APC for user and APC for the password. The program will come up. From there it will be easy to set whatever you want. OH!!! make sure your UPS has a network card installed. If not you can't change anything.
Nov 02, 2011 | APC Matrix-UPS 3000 (MX3000PE) UPS System
I need to know what the modular cable is that goes between the main unit and the batteries on a Matrix 5000. Is it simply a cross-over mini-RJ11 (handset connector) cable?
ccowl, APC has a great website. Have you tried it yet? The knowledge base they have on their products is huge. The cable you are speaking of may just be for monitoring battery voltage status, but that is only a guess. The interconnect cable could be a proprietary APC cable and only APC knows how it is wired "end to end" !!! 12fixlouie
Mar 16, 2010 | APC Matrix-UPS 5000 UPS System
Set the Battery Date on a Matrix 3000 UPS
According to the user manual (available here: http://www.refurbups.com/KB-M-Matrix) this can only be reset by using the PowerChute software available from www.apc.com and requires the unit to be connected to a computer.
Mar 06, 2010 | APC Matrix-UPS 3000VA UPS System
Dec 27, 2009 | APC Matrix-UPS 5000 UPS System
May 19, 2009 | APC Matrix-UPS 5000 UPS System
restart the ups by to turning off your ups and main source. and turn it on again. anybe the battery u purchase is deflected. change the new battery & test again. i suggest to replace other type of battery like neuton power, chloride powersafe as this type is much reliable and cost saving. the cost of the the problem if still occur it could the setting of the UPS that it to configue.. ask the vendor to check your ups
Mar 26, 2009 | NEC APC Smart-UPS 3000 RM 3U...
APC - UPS - Matix/Symmetra Enterprise UPS Symmetra 12KVA Expandable to 16kVA N+1 Master Frame (SY12KEX) UPS System Logo
254 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
