Question about Dell Axim X51v Pocket PC
Blue tooth ear device on x51v
It finds the device but then i have select services to use this device and the box is blank cant get it to pair
    Sergeant:
    Champion:
  • 317 Answers
You might need to authorize the device in the bluetooth settings menu, also, make sure that the headset is compatible with your PDA
Posted on Jan 10, 2008
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
How can I conect to my HTC wildfire when searching my phone cant find my plantronics Many thanks
You have to put your blue tooth device into discovery mode,Most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds when turning the device on,then when you are searching they will pair ,now you will be asked for a pin or pairing code.Most blue tooth device manufactures use a factory pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 19, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
I need the manual that came with my jabra blue tooth
Having the model number of the Jabra would be extremely helpful.
Most Bluetooth devices have a default pairing ID of 0000.
As for turning the volume UP or down, depending on what ear it is worn on, is nothing but trial and error.
Turn on your phone, go to settings (or tools) and turn on bluetooth. Select find device:
Turn bluetooth JABRA on and HOLD the power button until the Jabra flashes. (this means it is sending a bluetooth signal) Your phone should see it and ask for a pairing code. Enter 0000
A message on your phone should indicate you are paired.
Good luck.
Oct 08, 2010 | Cell Phones
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
Take care.
Sep 12, 2010 | Cell Phones
How do I send a picture message via bluetooth from my Samsung Moment
Hi
Via wap:
Go to: www.samsungmobile.com, register a free account then go to the play menu, click photo club and you should then see a photo studio tab click this then Launch mobile studio, it could take a while to launch but once it has you can select your phone and upload images, edit them then save them to an online photo-album which you can then access via wap and download your images.
Via Blue-tooth:
Make sure your computer blue-tooth is set to be visible not hidden.
The goto: Settings > Connectivity > Blue tooth > My Devices > Search new device (activate blue-tooth if it asks) select your computer enter a code, a box should the pop up on your computer screen saying samsung wishes to pair with you and it will ask you for a code, enter the code you put into your phone then find your computer on the list of devices select options and authorize device, this will allow your computer to send files to your phone without you having to click yes every time.
Now go into your blue-tooth program select send file or object push the browse through your file's until you find the picture you want to send then select send. The picture will go into the images file in your "Fun box"
Thanks
Aug 13, 2010 | Cell Phones
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Hi help plz
What type of phone do you have? When you try pairing with your phone are you sure you have activated the option? If not, here's what to do. Hold the call button on the H500 until the blue light stays on, then with your phone go to the bluetooth option and select search for devices. It should be able to find it then.
Sep 03, 2007 | Motorola Mobility H500 Wireless Headset
Dell Axim X51v Pocket PC Logo
29 people viewed this question
Alun Cox
