Question about Hoover Vacuums
Hoover Windtunnel is only cleaning (suction power) approx. 1/2 as powerful as it was when we purchased it approx. 4 years ago. I bought new Hepa filter and replaced the fileter on the side. I looked for possible build up of dust/dirt etc. and all channels are clear.
    President:
  • 1,865 Answers
There is also a filter inside the drum fan, you didn't provide your model number, so i cannot tell you exactly how to remove it.
Posted on Nov 17, 2009
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
19 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
