Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
Green and yellow images appear to be orange on the screen of my Sony trinitron wega tv. The CRT does not receive green colour and hence there is no green colour on the screen
    Scholar:
  • 86 Answers
Hello my fellow electronics tech. it seems that you know something about electronics. i would check the color transistors on the circuit board on the back of the crt neck. i believe it is supposed to be around 5v per transistor. one way to be sure is to match voltages with the other two amps and see if the green has no voltage. you then make a resistance check. make sure all power is off and the voltage has been drained from the set. check the caps by the color ic also with an esr, or use your ohmmeter.test your color ic for correct voltages that could cause erratic color problems. thank you very much and please rate my solution
Posted on Nov 17, 2009
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green or pink colour invading the screen from the sides of tube
I believe that your problem may be caused by a magnet, yes although harmless at most times it will mess up the image on your screen. Their may be something emitting magnetic waves to close to your tv.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green is gone
try altering the external video equipment to give out composite or CVBS.
It currently maybe on RedGreenBlue mode, i.e all colours are being transmitted on a different wire. one signal path maybe faulty
Aug 05, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
