Question about Sony Cyber-shot DSC-W55 Digital Camera
Everytime i power on it tells me to turn power off and then on again. When i do, the same problem occurs.
  • wayne_decote Nov 17, 2009
    I am looking for a reason for the error or solution, asking me to bang or tap on the device is not comforting in that I do not want to cause further harm to the camera
  • Sony Master
  • 17,970 Answers
This has to be the common failure mode or a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and #7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired: Review here for the solution steps.
Hope helped with this.
Posted on Nov 17, 2009
  • 10,594 Answers
This is problem of lens mechanism when it gets stuck/ broken/ misaligned or its optical sensors become defective.
In all above said cases lens mechanism does not send initialize/ reset signal to system control chip that cause 'turn power off and on again' error message.
Need to replace lens assembly in camera to fix this problem.
Some times tapping camera gently solve the problem if lens mechanism stuck, broken or misaligned status can not be corrected by tapping.
If you want to replace lens assembly by yourself, let me know to provide you part number info.
Thanks.
  • Shahid Electronics
    Shahid Electronics Nov 17, 2009
    :) I provided you reason and solution.
    Never asked to bang it, just tap it gently.
    any way..
Laptop freezes everytime when i remove charger...
Try changing the battery, if windows 10, the power settings may need adjusting..just Google power settings windows 10
Nov 01, 2017 | Computers & Internet
97 buick skylark not starting
sound like powertrain control module is not powering up everytime
Aug 09, 2009 | 1997 Buick Skylark
Blue screen error AOE 2, vista Dell 1520, G8600 video card
ok if your getting frequent blue screens your laptop cant handle whatever your doing on it, usually it means the power supply isn't powerful enough to run your gear or you've got to much junk on your laptop taking up memory try run a hdd cleanup wizard, if this doesn't work get back to me and we will go from there
Jun 10, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
LG 42pc3r, Starting problems.
First thing to try is a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this doesn't solve the issue, it sounds like your TV's connection between the power supply and the mainboard is defective. If the power supply was shot, you would hear nothing at all. I hope the above step helps.
Sep 15, 2008 | LG 42PX4DR 42 in. Plasma TV
Logitech web cam
Dear Friend,
please uninstall your webcam from your computer and then restart your system. Now you install ur webcam cd again. Be carefull to fill the each field properly. It may be that in the intial period some field you have negotiated that is why this problem is occured with you. Now your problem have been solved. have a good day.
Jul 31, 2008 | Logitech QuickCam Messenger Web Camera
Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Apr 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
