Question about Kenmore Freezers
Groaning Kenmore 13.5 cu. ft. Upright Freezer
I have a Kenmore 13.5 cu. ft. Upright Auto Defrost Freezer that makes a groaning noise on an intermittent basis throughout the day and night. The temperature is fine, food remains frozen.
What is cause of noise and how do I fix it.
bph
  • 612 Answers
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Posted on Nov 17, 2009
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
How do you defrost a older modle 13 cu ft standup freezer ?
Empty it out....pull the plug... get out the hair dryer....when all of the ice is thawed and the water soaked up then you plug it back in and restock the food...
heatman101
Jan 30, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Upright freezer shuts off and leaks when there is any kind of ice buildup. has done this twice in 7 months. is this normal or is it on its way out?
I suggest checking the defrost circuit. Make sure the drain in the back of the freezer is clear first. Then check the defrost timer, switch, and heating element using a volt meter. You can download a schematic from the Sears/Kenmore website.
Jan 19, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
223 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
