Question about Kenmore Washing Machines
Dryer only dries on low heat, I checked the lint filter and cavity as well as the exhaust and it is free. I also ran a dignostic and it shows F28. I`d like to know what may be the cause of the problem. This is a top loading Kenmore Oasis gas dryer model 110.77087600
  • Kenmore Master
  • 19,396 Answers
Hi.
Usually it is a bad timer. Before replacing timer the valve, coil, and regulator must must be tested.
Here all diagrams and parts for your appliance:
If you want to get a quote on repair you can call the phone number listed on the owners manual.
Regards.
Posted on Nov 17, 2009
Fisher Paykel DE06 electric dryer. I have to run loads twice to dry.
Did you check the duct going out of house for obstructions?
Oct 14, 2017 | Fisher Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Frigidaire affinity dryer takes long to dry
it could be the tempature of dryer is low but more likely the clothes are not spun dry as used to be .
Mar 05, 2015 | Frigidaire Dryers
Dryer beeps while drying
Most likely you have an excess of lint hampering air flow from the dryer. Vacuum out lint filter area, gently remove aluminum exhaust duct behind dryer and make sure it is clear and debris free. Also check exhaust duct port on back of dryer and that the vent going out of your house is clean and not stuck closed or clogged.
Jan 04, 2013 | LG DLE2101 Electric Dryer
After one load, dryer stopped working. lint
With the exhaust clear, you need to be sure that air is actually moving. It could be a bound or bad exhaust blower.
Mar 28, 2010 | Bosch WTMC3500UC Gas Dryer
Cloth dryer does not dry
check you lint filter and your exhaust, where the dryer puts the air outside
these have a tendencie to clogg as well
this will quickly slow your drying times
Oct 05, 2009 | Dryers
It turns on and it heats up but it does not dry the clothes
Hello. W/D here. The problem with your dryer usually isn't too serious, and the most likely cause is easily remedied. If it'll run, and heat up, that's great. It sounds like you have a restriction in your exhaust circuit.
Unplug your dryer and scoot it out to where you can get to the vent ducting. Lots of times there are loops and humps in the ducting behind the dryer that just love to collect debris. Disconnect it and, holding the duct like a "U", take it outside and clean it out. While the duct is off, clean the dryer exhaust cavity and the vent where the dryer exhaust exits your house. Remove the lint screen and inspect/clean the cavity below it. A dryer brush (looks like a giant bottle brush, ~$10 at Lowes, H/Depot, W/Mart) is really handy for this type of cleaning. This should correct your problem.
Hope this was useful to you.
Regards, --W/D--
Jul 18, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer heats up ands pins, but it takes forever to
Hi, First thing to check is the 4" venting to the outside. Make sure it is free of any lint and that there are no kinks in the hose. If this is a gas dryer, the couls on top if the gas valve could be getting over heated and not opening the gas valve later in the cycle so there will be no heat.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Not Drying
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Oct 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
