Question about Sony Cyber-Shot DSC-S50 Digital Camera
PC Mode I have one that for 2 secs maybe, I can see something I could take a picture of.  Problem is that on second 3 the camera screen has switched to saying PC Mode, even though it is most definitely not attached to the computer.  I have tried removing the battery and the cards and putting them back in, and still only get PC Mode.  Someone said something on another board about possibly a reset button, but I don't know if the sony dsc-s50 has one.  Has anybody else had a similar problem, or does anyone know if there is a reset button and where it is if there is one?  I'd really appreciate any help I could get.  Thanks in advance
  • asim4530 Jun 29, 2008
    Err16/60
    sony s50
    Err16/60
Err 16/60
Posted on Jun 29, 2008
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Cameras
Cannon sd 600,self timer How to use the selftimer
1. Make sure the camera is in shooting mode (silhouette of camera)
2. Press Func/Set button
3. Scroll down to Drive Mode icon (usually single square)
4. Use left/right arrow to select 2-sec or 10-sec delay (clock with 2 or 10 next to it)
5. Press Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before snapping the picture. Remember to set back to single shot (single square) or continuous shooting (three overlaid squares) mode when done.
May 28, 2008 | Canon PowerShot A520 Digital Camera
EX-S1: fault in function and data transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 04, 2008 | Casio Exilim EX-S1 Digital Camera
Self timer
1. Press the Func/Set button
2. On the left side of the LCD, scroll down to Drive Mode icon (usually a square, third item down)
3. Use right arrow key to select clockface with 2 (2 sec delay) or 10 (10 sec delay)
4. Press the Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before a picture is taken. Use the same steps to go back to normal (square icon) drive mode.
May 01, 2008 | Canon PowerShot A710 IS Digital Camera
Pictures stays on lcd screen too long
In the auto review section (under the setup menu) change from 5 seconds to 1 second.
Dec 26, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Timer on samsung digital camera?
Sure ... be sure to use a tripod or other device to place the camera for stability.
  • Set the MODE DIAL to your desired photo setting
  • Press the SELF-TIMER button on the button pad (looks like a clock/timer on the right button pad)
  • There are three settings
    • 10 SEC - 10 seconds will pass until the picture is taken
    • 2 SEC - 2 seconds until the picture is taken
    • Double self-timer - a picture will be taken after 10 seconds, and then after 2 seconds a second picture will be taken.
  • Press the SHUTTER button to begin the timer.
  • Jump in the shot! =)
Please rate FixYa! ThankYa!
Dec 15, 2007 | Cameras
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Sony Cyber-Shot DSC-S50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
