Question about Sony Video Cameras
Hi i have a Sony CCD-F380E Camcorder it has not been used for a long time plugged it inand charged the battery but when i turn it on all i get is a flashing warning light in the desplay and the eject dosnt work can you help thanksDan
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Posted on Feb 03, 2008
SOURCE: sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Posted on Jun 08, 2009
ginko
  • 19396 Answers
SOURCE: manual for camcorder/sony-hi8 camcorder-ccd-trv68
Try the link below:
Video Camera Recorder
Posted on Sep 08, 2009
SOURCE: Have a Sony CCD V9 camcorder. Stored it for years
Use a hairdryer to warm up the cassette area. My camcorder did same thing and this worked.
Posted on Apr 09, 2011
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
Icon
The icon you see is "EJECT" tape. It shows there is a problem with unit but cannot be defined without having unit checked by a pro tech
Apr 06, 2008 | Sony Handycam CCD-TRV37 Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony ccd-trv68
Unit has circuit problems, have serviced
Apr 18, 2007 | Sony Handycam CCD-TRV68 Camcorder
Sony camcorder stopped working
Your batteries have croaked and need to be replaced.
Mar 31, 2017 | Sony Handycam CCD-TRV67 Camcorder
New Batter won't fully charge and camera won't power off
The battery will not hold a charge or cannot be charged at all.
Follow the steps below to troubleshoot this issue.
IMPORTANT: It is recommended that you only use a Sony® brand rechargeable battery.
  1. Remove the battery from the camcorder or charger.
  2. Ensure the metal contacts on the battery are free of corrosion.
  3. NOTE: If necessary, the metal contacts can be cleaned using a soft cloth.
  4. Reinsert the battery into the camcorder or charger.
If the issue is still unresolved, then the battery may need to be replaced. If still unresolved after trying a replacement battery, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jan 04, 2007 | Sony Handycam CCD-TRV87 Camcorder
Won't turn off
the On/Off/VTR Switch doesn't function anymore and the camera is a month old. Basically anytime the battery is in the camera or the camera is plugged in, it remains 'On'.
That means you can't charge batteries or use VTR mode, or turn the thing off. Way to go on this one Sony.
Oct 12, 2006 | Sony Handycam CCD-TRV87 Camcorder
Video Cameras Logo
262 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
