Question about Dell Inspiron 1525 Notebook
Cannot detect hard drive when I turned on Dell
It's possible that I have a virus on the laptop, but since it can't find the HDD on boot, I don't know how to clean a virus off of a computer that won't boot. I'm working on an older laptop until I can figure out how to try and see if the HDD of the new laptop is really dead or just infected. Any assistance would be greatly appreciated.
thanks.
spinner girl
    Scholar:
  • 101 Answers
Can you run a hard drive test in BIOS (press the F2 key at start up). See what that tells you. If you have critical data on the drive and it is failing you will want to get it out and plugged into a USB adapter and try to get the data onto another computer.
Posted on Nov 17, 2009
    Sergeant:
  • 271 Answers
It's not dead or infected!! When the laptop turns on, press F2 this gets you into bios. Go to "Boot Sequence" If "Hard Drive" is listed there, then your hdd's dead! if not, go down until you highlight your hard drive. Mine says: HDD:C press space. it should now have a number next to it. Press "Space" on all the other numbers until your hard drive says: 1.HDD:C or whatever your harddrive says! press "Esc" and press save. now your hard drive should work. This might work for your laptop if your bios is "A011"
My computer froze so I turned it off and when i went to turn it back on, it says no bootable disk insert boot disk and press any key. Ive tried everything but it wont start up. And there is no disk that...
Sounds like your hard drive is going bad. Best thing to do is to take it to a shop and ask them to check your hard drive. Or, if at all possible plug it into another PC externally with a external HDD kit and check it with programs such as crystal disk info.
Best of luck
May 23, 2011 | Gateway M-7315U Notebook
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to...
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Aug 29, 2010 | Dell Inspiron 1525 Notebook
My wife drop the laptop on the floor and since then when i start the laptop it says no boot device found.
Two possibilities here:
1. When your laptop was dropped, the connecting between the hard drive & the laptop's motherboard became loose, & as a result the motherboard could not properly detect the hard drive. Solution here is simple: Try removing the hard drive & replacing it back in the laptop & see if this resolves the problem.
2. If the case did not turn out to be as described in point (1), then most probably your hard drive is damaged as a result of the fall. In this case you will also need to remove it off the laptop, but you will have to buy & install a replacement hard drive, & re-install the operating system & all other software.
The document at the following link describes how to uninstall/install a hard drive in your laptop's model:
http://support.dell.com/support/edocs/systems/latd600/en/sm/hdd.htm#1123687
Aug 25, 2010 | Dell Latitude D600 Notebook
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
Will not boot up
From what you describe, you may have a HDD failure. The Inspiron 8000 has a serial bus for the IDE drives and if one drive fails neither will work (If HDD Fails, the CD drive will not read)
Reseat both the HDD and Optical drive and make sure they are detected in BIOS. If HDD is not detected, replace it.
Mar 11, 2010 | Dell Inspiron 8000 Notebook
When I turn on my Dell Laptop it says....internal hard disk drive not found
Hello
Ok, this can be very bad news, or just a loose cable.
If you boot up your laptop and you get this message, it means that the bios cannot detect that there is a HDD plugged in to boot from.
Thus, your computer will not boot.
If you start the laptop, can you hear the drive start spinning up? If not, this might be because the drive does not get power.
You can test this by plugging your HDD into another computer. If the problem persists, your HDD is done.
If the problem does not appear, then you did not plug the power cable in correctly.
Hope this can steer you i the right direction.
Kind regards
Andrea
Dec 27, 2009 | Dell Inspiron 6400 Notebook
I have two Dell Latitude Laptop C500/C600 exhibitting the same problems with detecting the primary Hard Drive. The drives show up in the Bios (I have tried several drives, all pulled from other working...
if hdd is detected in the bios but cannot be detected when booting to windows then do this.
1. turn off laptop, press and hold on the Fn key then press power button once
2. psa test will run and check if it shows your error codes such as 0141 - 0142 - 0146 this means hdd needs replacement.
Oct 14, 2009 | Dell Computers & Internet
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n cx13a013
One word. VIRUS. You know, or you deleted one of windows boot files. Basically, switch to a Mac.
Oct 19, 2007 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Dell Inspiron 1525 Notebook Logo
187 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
