Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have been having issues with connection with xbox live using the router. I do remember the globe light being more solid before and now it keeps flickering??
    Novelist:
  • 149 Answers
Try unplugging the router for about 30sec. to a minute then plug it back in. This will allow your router to reset back to default conditions. Also if you type in the default IP address from your computer you can also adjust you configurations like that. This will allow you to control what items have access to your router. You can also add a password to your router. This will stop anyone from the outside to hack in to your router and block things that you do not want block like you XBOX. The default ip address is 192.168.0.0 this again is common. Please rate this
Posted on Nov 17, 2009
I have a D-Link Router, with an antenna that screws off, and now won't tighten. The entire copper piece outsde the router comes out. One month ago I was able to connect to XBOX LIVE, but now It wo
yes it can be, one antenna receives(Rx) and the other transmits(Tx)
other reasons are
1.) encryption of the router is set wrong
2.) router firewall maybe blocking (put Xbox into the DMZ)
3.) router was hacked and you no longer have control of it.
4.) you have been ban by Xbox live (check your email)
5.) Xbox wifi may be damaged or off.
theres more but start with the easy ones first.
Jul 08, 2012 | Computers & Internet
I need to log into my router which is an SMC SMCD3GN. The same problem I need to access my router to open ports for Xbox Live. I even tried the password diabloman posted about 8 months ago. Please Helpppp.
Normaly you do not need to open any ports for XBOX LIVE, XBOX LIVE uses the web connection that you'r XBOX uses to connect to the internet, unless you are using something i don't know, my son is using XBOX LIVE and i never had to open any ports on my router/fierwall.
if you can't remember the login for the SMC just reset it to factory, then login with SMC default user and password
Dec 04, 2010 | SMC Computers & Internet
How do i port forward my tew 432 TRENDnet router. I can play multiplayer on xbox live but not head to head. Keeps refering to my NAT settings. Thx
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of internet explorer
Step 3 : Click Login
Step 4 : On the Left Click Access
Step 5 : Choose DMZ
Step 6 : Click Enable ... And Assign the IP Address of the Xbox /PS3/Wii in it
Step 7 : Click Apply
Step 8 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 9 : Plug the power cord back to the router and wait till the lights are Solid
Step 10 : turn On the Xbox/PS3/Wii
Step 11 : Test the Connection
Step 12 : If Still the Same ..
Step 13 : On the Left under Access Click Firewall Rules
Step 14 : Disable it and Apply
Step 15 : Do Steps 8 through 9
Step 16 : Test the Connection
let me know if this works
Regards
TOM
Nov 19, 2010 | Trendware TEW-432BRP Wireless Router...
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I cannot connect to xbox live. I've called numerous times to microsoft with no results. I've called my router company to open gaming ports, which i did and still nothing. Ive gotten a new xbox, and it...
if you are using a router then you will have to set the connection up your main line to allow the connection to be made. if you are direct connecting with the modem to the xbox and its still not connecting then the xbox live server is down. I used to run into not connecting to xbox live alot more through using my router because my router was old and good gaming on live requires a good gaming router. check to see if your computer is acknowlledging your router, And if it is then, Make sure your router is up to date. sounds like a router issue. post back with any more help if its needed :-)
Oct 20, 2009 | Microsoft Xbox 360 Console
How do i find my WEP key, I have a Belkin 54g router
hi im an xbox live support representative
you could actually just call your router manufacturer so they can provide your'e wep key
if you still have some issues just call xbox customer support
thank you
Jan 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
XBOX Live & Netgear Router Help!!!!!!!!!!!
You need a excellent signal to your Xbox. Xbox requires a constant connection. My son as an Xbox and we had to run a wire connection to the Xbox no problems after that. Or you need to move your wireless router to the same room as your xbox to get a stronger connection.
Please rate my response.
Jan 07, 2009 | Belkin (F5D5231-4) Router
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
Sep 30, 2008 | Video Game Consoles & Games
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
XBox 360 not compatible with Motorola WR850G
Motorola WR850G router may fail to connect to xbox live after update to firmware 6.1.4. I was able to correct the problem. My solution was
Go in xbox >> network config >> IP and use Static option. Set the xbox to an IP in the range allowed by your router configuration. The router IP config range is found in the router config web >> Lan section. Then I set my router config >> Routing >> DMZ IP Address setting to the xbox ip I just assigned to my xbox. Restart router using the restart button on the Basic page of router config. Restart your xbox and attempt to login to xbox live. This solved my problem.
As a side note, on the xbox networking test page, the xbox live status message will allows show they are aware of a problem with xbox live login. This is a lie. For that reason I postponed trying to fix my router problem thinking it was an xbox issue, it is not. Once you finally connect to xbox live you will still notice this incorrect message remains. Microsoft developers ****...
Dec 26, 2007 | Arris WR850GP Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
114 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
