Question about Korg TR76 76 Key Synthesizer Workstation
When I change the ic battery in my Korg Triton Extreme...will all the factory data still remain?, or when I remove the old battery...does it get wiped clean...and I have to "reload" everything somehow?
  • 129 Answers
Yes all the setting will be turn into default setting or factory setting . So first look all the setting and note it and remove the battery so that you can get tehr previous setting. Best of luck
Posted on Nov 18, 2009
Testimonial: "Thank you. I changed the battery in my Triton Extreme..and you we're correct....all my factory settings did remained. Thanks again!"
No sound
Posted on Oct 16, 2010
If the seq. button on my triton doesn't work every time i
push it is there anyway to fix that problem. like do i have to
replace it?
Posted on Jan 06, 2010
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
Korg triton studio Change voltage input from 110v to 220v
Safest thing is to use a transformer. If it is only 35 watts, that is pretty small.
Often you can find a small "control transformer" that has dual primaries for 120/240 volts.
Connect it as an "Autoformer". In this connection you would only need one thaat would handle half the 35 watts... However, the smallest is probably 5 watts giving lots of capabilty. Google "autoformer" to see how to connect it. Essentially the primaries go in series and you take you 110 from one-half this combination.
The secondary of a control transformer used this way would NOT be used but just taped for insulation.
You might contact a heat and ventilation company as they may have one... even one that was removed for very low cost.
Aug 15, 2009 | Korg TR76 76 Key Synthesizer Workstation
Battery voltage ic is low for triton extreme what is this
Pry off the small round plate underneath your Triton and stick in a CR2032 Battery
TRITON Extreme Operation Guide
Jun 11, 2009 | Korg TR76 76 Key Synthesizer Workstation
Low battery voltage issue
I just replaced mine. Your keyboard will not self-destruct. Go to Radio Shack and buy a CR2032 ($5 or so). Turn your TE over. Unscrew the hatch. You'll see the battery is in reachable distance. Pop it out. Put the new one in. That's all.
Mar 21, 2009 | Korg TR76 76 Key Synthesizer Workstation
Sticky keys on Korg extreme
I just changed the key on my Korg Triton Studio 61. It took some time, but it wasn't that hard. You'd better have a power screw driver. I had to take out at least 30 screws.
Do this at your own risk. Don't blame me if you mess up your keyboard. I'm telling you. If you're not that handy, don't try it. Pay attention to detail and be careful.
The Steps that I took
1) Turn your keyboard face down. Make sure you put it on something soft so that you don't scratch the face of your keyboard or damage your knobs or the pitchbender.
2) Remove all the screws on the bottom panel and remove the panel.
3) you have to take the entire keybed out. Lots of screws! I had to remove the "assignable - midi input/output board" to get it out. MAKE SURE THAT YOU DISCONNECT ANY CABLES THAT CONNECT THE KEYBED TO THE REST OF THE KEYBOARD. I had to disconnect the keybed at three different places. These connector cables are NOT strong and if you pull too hard, you WILL break them.
3) Once you get the keybed out, you have to remove the plastic binder that goes at the back of the keybed. It holds the keys in place.
Then Snap the old key out. snap the new key in. Before you unpack your new key, make sure the old one is really broken. I had a key that wasn't broken. It had just come unsnapped. I snapped it back in and it was fine.
Put it all back together again.
I had a broken key before. i got it repaired and it cost me $150. This time I fixed it myself and it cost me $7.50
Mar 02, 2008 | Korg Legacy Collection
Korg TR76 76 Key Synthesizer Workstation  Logo
1,539 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Rabbit Brains
Rabbit Brains
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
