Question about Dishwashers
Hotpoint DW30 Stuck in cycle?? - Dishwashers
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Hotpoint dishwasher. Is the timer out?
maybe the float is sticking. did you check the float switch?
Aug 19, 2009 | Dishwashers
I have a Hotpoint BWD 129 and it's stuck on the wash cycle.
Hi this is abhishek welcome to fixya
its actually a timer problem,,,,,,better to fix it
thank u....
May 03, 2009 | Washing Machines
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
Hotpoint WMA 58 not draining
I would check pump to make sure its not blocked with object.
Jan 05, 2008 | Hotpoint WMA58 Front Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Feb 08, 2007 | Hotpoint Ultima WF865 Front Load Washer
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
