Question about Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer
The timer will run but the dryer will not start when I press the button.
    Scholar:
  • 196 Answers
I suspect a door switch. If the switch is broken/faulty then it will not allow the motor to start.
Posted on Jan 10, 2008
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
Hit start button but dryer will not start can hear the timer running
Open the dryer door and press the door switch , to make sure you hear a distinct " click " . If the door switch seems ok , then remove the rear dryer panel ( UNPLUG DRYER FIRST ) . On the blower housing , you will see a white 1" long piece ( thermal fuse ) with 2 wires plugged onto it . This is the piece you need to replace . #3392519 is the Whirlpool part number .
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Whirlpool LEQ8000JQ - My timer ticks but the dryer will not run when start button is push.
More specifically, the timer can be heard running, starts and stops when door is closed/opened, so not likely to be the timer. You have a problem at the motor. A wire off a terminal, the switch on the motor, or the motor itself.
Nov 29, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
