Question about Saws
Instructions on how to change out a 10'' blade on a Central Macinery Model 38533 table saw?
  • 152 Answers
Table saws usually don't have shaft locks... i either use a piece of wood to hold the blade or a c-clamp. crank the blade all the way up, remove the plate surrounding the blade and put a wrench on the nut,,, hint it is a left handed threading so... its counterclockwise tightens and clockwise loosens.... ps unplug it
Posted on Dec 06, 2009
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
How do I adjust the blade so that is parallel to the miter slot on my 10" table saw that is about 10 years old?
I fond some model numbers for table saws and I would recommend going to managemyhome.com with your model number and you can download a manual for this tool with detailed instructions on how to align so it is cutting square. I used the model number 11329884 just to see and I was looking at page 55
Aug 28, 2010 | Craftsman 10" Table Saw
Craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Dec 11, 2009 | Craftsman 10" Table Saw
I need an instruction manual for my delta shopmaster 10'' bench saw model number TS200LS. I know very little about table saws and need to change the blade and would like to install a dado blade.
you might try Dewaltservicenet.com and type in your model number in the middle of the page under need manual and see if you can find it there if not let me know and I will try and find one for you.
Nov 21, 2009 | Delta Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Jan 20, 2009 | Craftsman 10" Table Saw
Can't Get Blade Off
without a model number I cant look at a breakdown but if it is like the table saws that I work on I would assume that you removed the center plate to get to the hex nut and spindle, if so what I have to sometimes is put my wrench on the spindle and brace it against the saw frame and using a soft mallet tap on the hex wrench to loosen the nut. After this initial blade change the hex nut has to be tight but not to the point of breaking wrenches. If this doesn't work get me the model number and I will dig deeper to try and help
Jan 01, 2009 | Skil 10" Table Saw
Zero clearence isert
I'm not sure why the instructions said to change the blade in order to cut the slot. I've made several of the zero clearance inserts (for different blades) and always made the slot with the blade I intend to use it with. Of course, you need to match the inserts to the blades (I just tie wrap them together.
Aug 05, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
98 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
