Question about Sony KP-57WS500 57" Rear Projection Television
The pic is off there is bowing at the top and
The pic is off there is bowing at the top and bottom of the tv screen
    Scholar:
  • 60 Answers
Picture becoming distorted at the top/bottom of the screen is due to the convergence circuit going bad, and is a common issue with big screen projection TVs.
The convergence circuits will need to be repaired, which will generally require some soldering and ordering new parts for ~$75. If you want to get a TV technician to repair it then you will probably be looking in the region of about $300 for a repair.
Here is a link to repair guide for a Mitsubishi TV. Obviously a different model, but the convergence circuits are generally the same for most makes/models - this will give you an idea of the work involved to fix it: http://www.techlore.com/article/22530/DIY-Repair-Replacing-Convergence-IC-s-on-a-Mitsubshi-TV-Set/
Posted on Nov 17, 2009
Testimonial: "thanks great advise "
  • 10,594 Answers
Please check convergence out section as it sounds convergence out chips are bad and requires replacement.
Let me know if you want to repair TV by yourself to provide you more info.
Thanks.
silly girl
  • 513 Answers
SOURCE: bad picture at the top and bottom
If you're not a professional TV repair person, the following information is good only for reference. If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. You will need to change the Stk convergence amplifier Ic's. You will need to check for the proper Ic, but it might be an Stk 392-110 (Q751&Q752). These Ic's fail sometimes due to lack of heat sink grease, and also because they expend lots of heat. Good luck
Posted on Jun 19, 2006
ctf1800
  • 4402 Answers
SOURCE: problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 03, 2008
  • 2318 Answers
SOURCE: Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Posted on Apr 19, 2008
SOURCE: Sony kp-53s35 bowed picture on top and bottom
Big Irish, you were right on. I brought the tv in to a shop and ha dit diagnosed, a convergence ic was bad, they ordered me one and I soldered it in and got it working. ready for this I spent a total of $272 for diagniosis and part. in my op[iniom that was not bad at all tv has been working for over a month.
Posted on Jul 19, 2008
  • 87 Answers
SOURCE: GREEN BOWED LINES
You have a convergence problem Call a Sony service center make sure they use original ic's in this model cost is around 350.00 depending on area.
Posted on Apr 16, 2009
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
I have the same problem with a 61uwx10b. I
the ics could have been defective, or maybe you missed a resistor or something. the ics could short out and cause the tv to totally shutdown if dead shorted, as some of these have no fuses. I would doublecheck all your solder connections and make sure nothing is shorted out and look for other bad resistors. here is my tutorial if this helps
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 13, 2010 | Hitachi 61UWX10B 61" Rear Projection...
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Red bow on top and bottom of 61dx01b
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Problem with convergence
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bow at top and bottom of the screen
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
Bowing image top and bottom of screem
No im sorry there is nothing to do but replaceing the convergence IC
Oct 30, 2006 | Toshiba 55H70 55" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
