I'm not sure what your saying when you talk about the condenser on a dryer. Without a model number I'll have to guess your talking about a clothes dryer. All dryers have a cycling thermostat. If this is a regular clothes dryer, either this will be the problem or your vent hose is clogged. What sounds like is happening is something is cutting the heat off prematurely therefore it takes to long to dry the clothes. If the vent is clogged, it can't get rid of the air and this will cause the dryer to short cycle. The cycling thermostat will also cause this when it gets weak. I hope this helps but I'm not sure we are even talking about the same thing. Sorry.
SOURCE: CONDENSER DRYER IS LEAKING WATER
make sure it is pushed all the way in but it could be something simple like when it was moved water has splashed out into the inside of your dryer which will make it look like it is leaking had same problems like that with other customers dryers leave it to run and more than likely that it will dry itself out
SOURCE: Not collecting water in the tank
I assuming it is a condenser dryer ,have you checked the rubber gasket ,to see if it is damaged or has dirt on it that prevents it from making a water tight seal.
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
SOURCE: Water collects under dryer. Clothes dry. floor wet. Vent open.
You said, Water collects under Clothes dry on floor.This sounds like a condenser dryer that needs the water retention bottle empdied or the hose to the bottle is leaking.
Check these two things
Huuum
Please leave a rating before you leave the site!
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
The product a Hoover Family Magaload Condenser Tumble Dryer. The condenser is supposed to take the moisture from within the dryer and fill the water tank which is then emptied after a load.
