Question about GE Kitchen Ranges
I have a Ge xl44 gas range model# JGBS20WEA1WW and the oven does not heat up. the electric ignition glows red and kicks the gas on but the gas does not flare out (only about an inch) . it stays the same and the oven does not heat up to cook anything. please help
  • 4 Answers
SOURCE: GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Posted on May 18, 2007
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
SOURCE: GE XL44 pilot
I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
Good Luck
Jim
Posted on Sep 22, 2009
SOURCE: Have xl44 GE Range /Oven--Oven and Broiler will
Date: 8/2/2010
I have a GE XL44 oven. It's about ten years old. Oven would not turn on, so I replaced the igniter. The igniter has to light to "tell" the gas to come on. The part was $80 here in Oklahoma and it was super simple fix.
Pull the oven out of it's place and unplug. You can shut off the gas if your buidler placed a shut off valve.
1. The oven door pulls off without tools (I wish I knew this when I cleaned the oven last year) just open the door about three inches and pull toward your chin.
2. Remove the lower storage drawer.
3. Then remove the racks.
4. Remove oven floor. The oven floor comes off with two screws in back, then lift it about an inch from the rear and you can pull the front up, clearing the lip. This is a good time to clean the ten year old food off the oven floor.
5. You will see the aluminum burner. The lower ignighter is attached to the burner. The screws to the ignighter are at an angle, dont try to remove them with out taking the burner out. To remove the lower burner, get on your side and look way in the back of the lower drawer area. Remove the two screws at the very back where the oven drawer goes. You will also unplug the two (2) wires and the then the whole burner will lift up and come out, then you can remove the ignighter screws. Take the ignighter off and take it to a appliance repair store and they will sell you a new igniter. You can look on-line as well.
The new part does not have the connectors like the original, Just cut the old wires in half and pig tail them to the new part. The new part will come with ceramic wire nuts. This whole install takes about an hour, and will save you a service call. It can seem like a hard fix, but once you dig into it, it's pretty easy. Everything goes back together in reverse. This would be a good time to change the light bulb while you are at it.
These are the same type of ignighters that are on everything these days, hot water heaters, furnaces and they are the most likely to go out since they are used quite a bit.
Posted on Aug 03, 2010
  • 385 Answers
SOURCE: The oven will not light.. ge xl44 range/oven 10
More than likely you have a bad oven ignitor. It's not uncommon that they need repalced, they do go bad.
Posted on Mar 13, 2011
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
GENE
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 pilot
Good Luck
Jim
Aug 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44 GAS OVEN
there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
Nov 26, 2007 | GE JGBP28 Gas Kitchen Range
GE Spectra XL44
Easy to install you just have to remove the racks and the bottom of the oven. Call a local appliance store with the model # and ask for the ignitor.
Sep 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
