Monitor stop responding. No blue light indicating power on. Monitor totally dead
  • 643 Answers
Ok. This could be due to a number of issues.
One, it could be the plugin you have the monitor plugged into.
try to plug it into a different wall socket.
Two, it could be the power cord of the monitor itself, Depending on the name brand of the monitor, sometimes the power cable for the monitor is similar to the power cable that goes into the back of your desktop tower, you could try one of those if possible.
Three, the fuse inside the monitor could be blown ( if it has one ) If the monitor is no longer under warranty, you can try to take it apart, there should be a fuse somewhere along the power path, either on the cord itself, or somewhere close to where the power cord goes inside the monitor. The fuses are inexpensive to replace, and if you can find the fuse, just replace it with the same type of fuse from walmart, home depot, or lowes hardware.
Four, It could be the power inverter board for the monitor, depending on the name brand and the model of monitor, this could cost as little as 20 dollars to replace, and possibly as much as a couple hundred. This is also a relatively simple replacement if you google the monitors name brand with power inverter board.
Five, the mainboard inside the monitor could be fried, and at this point, unless your monitor costed over five or six hundred, it would probably be more economical to replace the monitor.
I hope this helps out, and thank you again for using fixya!
Posted on Nov 17, 2009
Monitor will not turn on
if the indicator light is just blinking or get turn to blue then get red the cause will be a bad electrolytic capacitor at the power supply board. if totally no indicator at all check for a bad fuse at the power supply board.
Mar 10, 2013 | Gateway Computers & Internet
No power
Look if you can safely get it apart for the fuse inside the unit and if possible test the power cord and where it connects, this is the place to begin---total dead units are usually easy to fix, follow the AC voltage from the wall or voltage source inside to the fuse etc.
Dec 20, 2012 | Acer S242HL bid LCD Monitor
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
Computer monitor don't work at all.
So basically your monitor's power supply system died.
Nothing much a non-technician could do about it.
Get it repaired, if under warranty, get a replacement before the coverage duration expires.
Jun 07, 2010 | Computers & Internet
TV will not respond. Red power light indicator
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2010 | Akai LCT2070 20 in. EDTV-Ready LCD...
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Monitor is totally dead
Through my past experience I mwould remove the solder point at the input power B+ line to primary winding FBT. If the HOT has shorted there will be no power.Straight to the point if you know where the HOT is , you can desolder the middle pin or collector of the HOT transistor. If you desolder the pin which result the power led light turn up. That indicates either FBT or HOT has shorted
Apr 19, 2008 | LG Studioworks 45 14" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
